Author Topic: Its time to build a 836 Turbo  (Read 106117 times)
Re: Its time to build a 836 Turbo
« Reply #525 on: February 14, 2013, 04:57:13 PM »
CarbonGuy and his dad were nice fellas. They are into prosthetic devices which is a little more in my college trained field.
Offline Bill/BentON Racing
    • BentON Racing
« Reply #526 on: February 14, 2013, 05:07:30 PM »
I want a clear,transparent,smoked,etc....CAM COVER,how cool would that be? ;)
Pay ,I don't know,2-300.00 be ok.Bet there'd be some polishing going on!!! 8) Bill
BentON Racing Website
BentON Racing Facebook
Offline BLUE71TURBO
« Reply #527 on: February 14, 2013, 05:28:13 PM »
I just knew that Sam Green put his Mini Cooper in his carry on and was over in the neighborhood
you don't see original coopers to often but with right side drive is even more rare
I did look to see if it might be Sam but he had a head full of hair:)))))
sorry Sam
Jim
                   Where is this at ?  Reminds me of when i visited Florida.  I felt like a rat in a maze........No mountains to look at to get my bearings ( in my head ).   Just highways each way with tall trees on either side and sky above.....claustrophobic !    :o
Offline Jim F
  • go baby go
« Reply #528 on: February 15, 2013, 05:16:20 AM »
You can shave my head for that one Sammy
Always my best mate Sammy
2002 RC51 1000 (SP2)
1983 GS1100EC Suzuki
1992 KTM500 2 stroke
1975 CB750/836 Honda
1978 GS750/840 Suzuki
Offline Jim F
  • go baby go
« Reply #529 on: February 15, 2013, 05:56:38 AM »
sorry Sam
Jim
ol
its going down Hwy 78
 going in to stone mountain Ga
that mini was very co
Offline Jim F
  • go baby go
« Reply #530 on: April 06, 2013, 08:14:00 AM »
One day I will get my turbo build back from Davids
and this might go on or I will never get any of the fast guys at track to ride it
might do something with this front end also........its from an aprilia
Cal-Fab swing arm (4 over) Bigger Brakes than the RC51 units and Brembos
Offline chris mcshifty
« Reply #531 on: April 06, 2013, 09:15:52 AM »
Sweet been wondering what's been going on with the build
« Reply #532 on: April 06, 2013, 09:19:04 AM »
Looks like a $hitload of epoxy on that head Jim. ;D Just received an Ohlins rear shock for my RC51.....different link arriving Tuesday. Shock is nice...low/high speed compression, rebound, ride height etc. Separate hydraulic preload is great too. ;)
Offline Jim F
  • go baby go
« Reply #533 on: April 06, 2013, 11:07:05 AM »
That head came off of a top gas bike (Twin plug head big everything). It was a sacrifice to the gods of speed
when he shot a 150HP shot of Nox (it was a progressive shot) and there wasn't enough timing backed off. Detonated the motor
and split the head.............He wanted me to weld it but he had another head and got that one going..........
Let me know how that shock works Mike
I will call soon
Jim
Offline Jim F
  • go baby go
« Reply #534 on: October 07, 2013, 09:15:20 AM »
WELL...................good news.............the wiring harness is almost completed, but
enough so that we started the bike last night and heat sinked the motor to operating
temperature. charging system is doing what its supose to be doing
 everything looks good and sounds tight. a little drip of oil coming from the shifter cover
but that's an easy fix.............going over to finish it tonight and get ready for Barber vintage this weekend
will keep you posted
Jim
« Reply #535 on: October 07, 2013, 09:23:36 AM »
Excellent news Jim. Long time coming huh?! It looked good as parts on the bench. It looked great as a bike. I know you're looking forward to that first throttle twisting ride  :)  Have fun at Barber's. Hoping you can do Bradenton too. Maybe we can get together in ATL first week in November otherwise.
Offline Jim F
  • go baby go
« Reply #536 on: October 16, 2013, 11:56:32 AM »
The journey has been long and sometimes aggravating but its going to be well worth it when its all said and done.
from my last post we did heat sink the motor and everything sounds good and tight. a couple of leaks around the mag
cover and shifter cover but thats it. checked the charging system and thats doing good. the wiring is going to be top shelf
once its done. the reason that I wanted David to do this was because  he did the wiring on his pro ET bike and its very
neat and tidy but most of all its all out of the way and of coerce it works. Yes its been almost a year but I would do it again
and I am with my black GS that is being tuned at livingoods.
SO the only thing that is not finished is the headlight, taillight and oil temp gauge.
got the bike home and my computer guy had sent over the correct drivers for the USB to serial port adapter.
got that working with the lap top. Down loaded the software from MSD for the MC-4 box. Hooked up the lap top
to the box, powered up the ignition and proceeded to down load the info that was in the box. This box came from a pro stock
drag racer so there are some things that I am going to change
The start retard setting was at 0 and that made the bike impossible to start when it was warm. He static timed his system to 38 degrees
but when you use a 24 volt starter cart to zing over the motor, its gong to start.
I set it at 10 degrees and after talking to Mike Rieck, I will change this to 15/20 degrees
I don't need a 15,000,00 RPM red line so I changed that to 9500 RPM,s
I put a MSD boost sensor on and the box recognized that as a 3 bar sensor and it showed up on one of the graphs to let me know
when the boost starts so we start to back timing down
I took the bike out for a short ride in the neighborhood and everything seemed to work fine, which is a good thing.
happy so far
I have decided to switch out the drag pipe that came with the turbo system and switch to a more user friendly system
I have also changed out to the stock pegs and controls too. its much more rider friendly now and still has the old school
turbo look
still have more work to do on the bike but we are much closer to getting it finished soon (I hope)
« Last Edit: October 16, 2013, 11:59:25 AM by Jim F »
« Reply #537 on: October 16, 2013, 12:14:42 PM »
Congrats Jim. It's looking good! Hope to see you and the bike soon. I'll be in town on the 3rd. Hoping you can do Bradenton too.
« Last Edit: October 16, 2013, 05:43:15 PM by Jerry Rxman Griffin aka MuthaF'er »
Offline dragracer
  • CB750F Dragbike
« Reply #538 on: October 16, 2013, 02:01:35 PM »
Very nice Jim. Patience has paid off.
  • Moderator
« Reply #539 on: October 16, 2013, 04:49:06 PM »
Hope to see you tomorrow Jimmy when we go to pick up the race fuel.
The bike sounds like a real drag bike now with all that elctrontrickery.  ;D ;D ;D ;D ;D ;D ;D
Sam. ;)
Offline ivanhoew
« Reply #540 on: October 17, 2013, 01:10:43 AM »
really looking forward to the graphs jim  :-)
just do it .
Offline Jim F
  • go baby go
« Reply #541 on: October 17, 2013, 05:54:00 AM »
Sam. ;)
call me when you get there.................will try to have lunch
    • BentON Racing
« Reply #542 on: October 17, 2013, 08:14:03 AM »
Jim well worth the wait! ;D Just put new F tank and  paint job back on Purple Rain turbo bike! They'll make a sweet pair next to each other! ;D Bill
Offline ivanhoew
« Reply #543 on: July 09, 2014, 02:13:49 AM »
I may be a bit behind , was this dynoed jim ?
just do it .
Offline Jim F
  • go baby go
« Reply #544 on: July 09, 2014, 11:18:33 AM »
had some set backs but its ready to go
gong to pick up the 1100 this week and drop off the GS840 and the turbo
had some minor glitches on the turbo with the starter, and moved the battery on top of
the MSD box to get it out of the back side of the turbo
well keep you posted
Jim
Offline ivanhoew
« Reply #545 on: July 09, 2014, 11:50:05 AM »
excellento , yes my battery is pretty close to the turbo on my 400/4 .
Robert.
just do it .
Offline Jim F
  • go baby go
« Reply #546 on: September 03, 2014, 02:39:52 PM »
Well I would say it's about time both the turbo and the GS 1100 are finally up at the shop for tuning I'll keep you posted
Jim
« Last Edit: September 05, 2014, 11:05:35 AM by Jim F »
« Reply #547 on: September 03, 2014, 03:13:35 PM »
Great news Jim. They are looking fine!
Offline Jim F
  • go baby go
« Reply #548 on: September 03, 2014, 05:54:01 PM »
My favorite side
    • BentON Racing
« Reply #549 on: September 03, 2014, 07:03:24 PM »
 ;D going to take Turbo to Valdosta I hope, just to show if not ride. Test and Tune 10-5 Friday. I'll be testing, Russ Jr. And partner Neil Potter and Larry will be there also. Keith, Jerry, Mike, Frank, Kenny and Todd, oh my we might have a little fun! Jim, time for the turbo to get some face/TV time! K, Bill
Imagine Kenny will be testing also. And Frank and Gladys be there also!  ;D 750 shoot out! Haha. Trey get your azz over here! Can crash here, can sleep on a lift! lol!  8)
