Author Topic: Its time to build a 836 Turbo  (Read 106113 times)
Offline Jim F
  • go baby go
Re: Its time to build a 836 Turbo
« Reply #575 on: November 20, 2014, 06:27:56 AM »
I had a sheet metal shop shier the aluminum for me
I bought the casters and the heating element from home depot (1500 W) and the thermostat.
 I had the Areo-space shop at Georgia Tech make the threaded plug (Odd ball threads)
that the element screwed in to, and welded everything up,
The material is 1/8th thick
I need to make a tray to sit over the element and a cover for the element and thermostat
but it worked great all weekend even when it was really cold
call me anytime Frank
Jim
2002 RC51 1000 (SP2)
1983 GS1100EC Suzuki
1992 KTM500 2 stroke
1975 CB750/836 Honda
1978 GS750/840 Suzuki
Offline ivanhoew
« Reply #576 on: May 31, 2015, 02:36:59 AM »
did this get on the dyno jim ?
just do it .
Offline Jim F
  • go baby go
« Reply #577 on: May 31, 2015, 07:04:46 PM »
Cough cough and clearing the dust from NOT
Doing anything with the bike.......
But the turbo and the gs1100 are going this week
Finaly
The last time the bike was up at the dyno
The top end was really lean and went from a
210 main to a 230 main and got the AF to 12.1
The needle was ok but lean just as it started on the mid range
Found a richer needle and that's in. So.... No more excuses
My business keeps me busy and I never get in s hurry to do anything
With my projects but I have to try and set time frames to finish them
Interesting thing about the gs1100 was that the first few runs
On the dyno it sounded like the clutch was slipping so Brian at Livingood motor sports
Ordered a new set of fibers and installed these and still had some slippage
Ordered stock plates and Barnett springs
Still slipping, not sure what to do. Started making phone calls to people that raced these bike
and the first thing to  check, and I didn't think about, (imagine that) was to make sure the pressure
Plate was not hitting the the hub and sure enough that was the problem
Added an extra steel plate and now it goes like stink.
Made some adjustments on the carbs so it's ready to go also
Oh yeah
I bought a bunch of racing parts for the 1100 motor
I threw in a lock up clutch just for the fun of it
Took it out today and everything is doing what it's suppose to do and there is no slipping with the extra steel plate but with the lock up there is NO slippage.
I'll will keep all posted and I promise that I won't be Christmas when the results are in
Jim
« Last Edit: June 01, 2015, 05:22:44 AM by Jim F »
Offline ivanhoew
« Reply #578 on: June 01, 2015, 01:19:55 AM »
excellent , really interested to see how it compares with my turbo 400 .times 2.09 of course ;)
just do it .
Offline bear
  • Leeton in Australia
« Reply #579 on: June 01, 2015, 05:17:42 AM »
I used to race those motors in speedway sidecars for quite a while Jim.
If you run the locker with the standard bevel gear driving the clutch be careful.
The clutch basket can crack around the base.
I've had the whole unit come away and blow out the side of the motor.
Spectacular, but not to good for drive or the hip pocket. ;D
You can pick up straight cut drive gears for them.
Oh..........and if you know a good welder, we used to weld up the basket as well from memory. ;)
Brian
« Last Edit: June 01, 2015, 05:22:36 AM by bear »
Offline Jim F
  • go baby go
« Reply #580 on: June 01, 2015, 05:30:23 AM »
Hey Brian
The lock up was just a fun thing to try and I got a really good deal
(Complete clutch assembly with extended cover, springs, fiber plates)
And if my drag racing friends don't push to hard and you guys know who you are
It won't see Any trips down the strip
I will revert back to the stock set up soon and shelve the parts for another rainy day
Hope all is well with you brain and will talk soon
Jim
« Reply #581 on: June 01, 2015, 12:49:04 PM »
Offline Jim F
  • go baby go
« Reply #582 on: October 07, 2015, 02:26:30 PM »
got it on the dyno and we are still having to go to larger mains
I thought we had this the first time but this is what I get for being just to damn busy
and not remembering what we did the first time
increasing jet size from a 230 to a 240 main
still lean and that's not good under boost
but hey
at least I got on the dyno and it still runs...............:)))
« Reply #583 on: October 07, 2015, 02:40:35 PM »
One step closer to perfection  ;)
Offline TurboD
« Reply #584 on: October 07, 2015, 02:51:00 PM »
Jim I have not read through the entire build, but do you have a fuel pump? Are you not using the Zenith carb?
Offline Jim F
  • go baby go
« Reply #585 on: October 07, 2015, 04:07:50 PM »
Yes on the fuel pump and it stays at 2.5 lbs under load and anything under full load its 3 lbs
I am using the Mikuni HSR42 flat slide
Offline TurboD
« Reply #586 on: October 07, 2015, 04:20:15 PM »
That should be fine. I have not worked with the Mikuni on a turbo, I have always liked and used the bendix.
Offline Bill/BentON Racing
    • BentON Racing
« Reply #587 on: October 07, 2015, 05:16:35 PM »
D, you get the kit?  ;D, Bill
BentON Racing Website
BentON Racing Facebook
    • BentON Racing
« Reply #588 on: October 07, 2015, 05:18:30 PM »
Jim, how does the flat slide work? Thinking about one when Purple Rain goes back together? Bill
Offline Jim F
  • go baby go
« Reply #589 on: October 07, 2015, 06:14:07 PM »
We are still trying to get the carb worked in
And hold a steady 12.1 AF although Brian is leaning more to
11.1 AF. Then start to add boost and watch retard kick in
And hope we still have consestant AF. As soon as I (Brian and David)
Get it jetted I will let you know
See everyone at Valdosta
    • BentON Racing
« Reply #590 on: October 07, 2015, 06:24:31 PM »
Jim, thanks, yeh Valdosta will be fun! Bill
« Reply #591 on: October 07, 2015, 07:44:26 PM »
How did it do on horsepower and torque, Jim? Did you get a graph? If so, please share. 8)
Offline TurboD
« Reply #592 on: October 08, 2015, 08:29:20 AM »
Bill Yes I did today. Thanks
Offline Fastbike
« Reply #593 on: October 08, 2015, 06:51:46 PM »
Scottly,
Jim probably hasn't seen your question, but I was there to observe.  The carb jetting was so lean, that I watched Brian screw the throttle open and the engine just didn't accelerate at all.  A/F ratio was showing about 15:1.  So to answer, no, there was no graph.  I'm sure when Jim receives the jets he ordered and installs them, then it's dyno time again.
I'm not as smart as I look, but I am pretty.
« Reply #594 on: October 08, 2015, 07:14:44 PM »
Thanks.
    • BentON Racing
« Reply #595 on: October 08, 2015, 07:24:35 PM »
LMAO,  ask him about the bored out carbs....18 to 1 at idle. He thought sensor wasn't working!  ;D, Bill
« Reply #596 on: October 08, 2015, 07:40:32 PM »
I went through the same thing the first time I put the FT on the dyno; it was so lean, I figured the sensor was bad, and spent two days researching, cleaning, and adjusting the sensor air-flow before yanking the stock muffler and inserting the probe directly into the open pipe.  :-[ :-[
Offline Jim F
  • go baby go
« Reply #597 on: October 09, 2015, 02:36:48 PM »
Thanks David and we will have dyno time soon................see you tomorrow at commerce
ET Finals
go team
« Reply #598 on: October 09, 2015, 05:21:40 PM »
Good luck guys!
« Reply #599 on: October 09, 2015, 05:28:30 PM »
Go hard boys
