Author Topic: Engine knocking  (Read 1524 times)
Offline jlatkins83
Engine knocking
« on: January 24, 2012, 10:41:41 PM »
I just rebuilt the top end of my engine but checked the rod bearing clearances while I was at it. Everything was in spec and the top end went together great. But now when I hit around 3000-4000 rpm I hear a "knocking" sound. It sounds like its more of a vibration of metal than a hitting of metal. I'm not sure what it is, thought it might be loose exhaust but I have those tightened down. Any help would be great! Thank you.
1978 CB750K
Offline jlatkins83
Re: Engine knocking
« Reply #1 on: January 24, 2012, 11:17:01 PM »
I forgot to say, the engine runs great at idle and start up. I also haven't timed it running yet, only static.
1978 CB750K
Offline City Boy
Re: Engine knocking
« Reply #2 on: January 25, 2012, 04:24:18 AM »
Hi.An oil pressure check with a gauge may be helpfull.How did you check bearing clearance with only top end apart?
'52 Kiekhaefer Mercury Rocket Hurricane KG4H
'70 750/RC 1000 Original Owner
'83 1100F
Re: Engine knocking
« Reply #3 on: January 25, 2012, 07:15:51 AM »
Not that its your problem but I had a vibration between a certain RPM range on a CB900F that was freaking me out,thought the top end had a major problem. Checked it out carefully with my helmet off and found it it was the glass in the mirror housing vibrating and rattling in that range.  Try to see if you also can get a better idea in the shop as to maybe what part of the engine is making the noise.
Offline jlatkins83
Re: Engine knocking
« Reply #4 on: January 25, 2012, 10:17:33 AM »
I fully rebuilt the top end and had the cylinders off, but I also had to split the case to find a dropped pinion clip. So I went through and checked for play in the rods and on the crank. I guess I should of mentioned that so I don't sound like an idiot. Thanks for the advice.
1978 CB750K
Offline City Boy
Re: Engine knocking
« Reply #5 on: January 25, 2012, 02:32:39 PM »
Ok.If the bearings passed the visual and measurement tests you are likely looking elsewhere for the problem.You also checked the main bearings right?
'83 1100F
Offline Danno
Re: Engine knocking
« Reply #6 on: January 25, 2012, 06:28:05 PM »
sure you got all the wrist pins right?
also you can get vibration from baddly synched carbs it makes the primary chain slap back and forth by the pistons being out of sync
Offline jlatkins83
Re: Engine knocking
« Reply #7 on: January 25, 2012, 08:08:17 PM »
Bearings are good, as for synch that can be out. I need to rebuild my carbs but it is like looking for atlantis to find a rebuild kit for 78' keihin carbs. However, I got a tell tell clue today that makes me think the noise is still in the exhaust. The mounting flanges are much thinner then the stock finned type and I think that the cylinders with studs (long story why only some have studs) aren't able to tighten all the way due to lack of thread on the stud. I also checked the whole engine by listening to it in various spots with a rod (sorry I don't have a stethoscope)  and all sounds are like normal running condition. I will keep posting when I find the issue. Thanks for all the help, it can be a bit lonely and frustrating in the garage by yourself.
1978 CB750K
Re: Engine knocking
« Reply #8 on: January 25, 2012, 09:15:15 PM »
Somebody over in Seattle give that guy a HUG if he is lonely in the garage and lend your ear also.  Seems to be some peeps over there I bet  ;)
Offline scunny
  • don't call me expert
Re: Engine knocking
« Reply #9 on: January 26, 2012, 02:53:43 AM »
group hug.
since you say the exhaust isn't being clamped fully, is there any sign of blowby, it can make a wierd sound.
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
