Author Topic: What chain and sprockets for CB750 K2?  (Read 1763 times)
Offline KC_Northstar
« on: January 25, 2012, 02:38:51 PM »
OK, I'm lost here on what chain to use.  I have a CB750 K2 and I would like to change
the front sprocket to the 17 tooth.  I see that Hondaman recommends Diamond Powersports
Non o-ring chains in his book.  Where can I get one?  How many links do I need?
what brand of sprockets should I use.  I need a 530 chain, right??  Can someone
educate me on chains for the CB750?
KC
KC
1971 CB750-K1
1972 CB750-K2
1971 SL350-K1
1971 SL125-K0
1979 CM400A
Offline Danno
Re: What chain and sprockets for CB750 K2?
« Reply #1 on: January 25, 2012, 05:55:07 PM »
http://www.diamondchain.com/products
here you go a link to diamond chain
« Reply #2 on: January 25, 2012, 07:24:05 PM »
You do have Google ??  :) Lots of info and that is a good chain I am sure.
Offline Doum
« Reply #3 on: January 26, 2012, 05:07:09 AM »
Personnally always O-ring chain,will last for year instead of a non o-ring
Offline solo 2
« Reply #4 on: January 26, 2012, 05:35:02 AM »
A properly lubricated non-oring will last just as long on anything other than high HP bikes, I never buy orings anymore as I didn't find enough difference for the cost. If you convert to 520 the chains seem to be more reasonably priced.
You know you've achieved perfection in design, not when you have nothing more to add, but when you have nothing left to take away.
