Logo merchandise is available at the SOHC/4 Shop
Kind of a dumb question, but did you put the exhaust gaskets in?
Quote from: Dimitri13 on January 26, 2012, 12:08:43 amKind of a dumb question, but did you put the exhaust gaskets in?Yeah gaskets are fine - but that's not where the leak is. It's leaking from where the pipe meets the stub - not where the stub meets the head.
All stock...Actuallly, as I look at this, mayby the clamps are stretched....Damn, those are expensive!
[Also we're back to your idea of slipping a shim in there. I'd put it between the clamp and the pipe, not the pipe and the spigot, which would be hard to do.
