Author Topic: another carb question...  (Read 888 times)
Offline Bandit18
  • I'm not a freakin Genius
  • 78' CB550K
« on: January 28, 2012, 05:29:29 PM »
Okay I finally got the pressed in slow jets out of the 78 550k and the float pins out by heating the post with a torch.Now I removed the adjuster screw and find a spring a washer and a o ring,my question is the o ring is split so do I need to find another one or can I still use the split one.I wasn't sure if it was there to seal or just to be a seat also I probably need to remove these when I blow compressed air thru the openings right? Thanks
72500john
Re: another carb question...
« Reply #1 on: January 28, 2012, 05:35:15 PM »
replace it.  orings are sealing devices.
Offline Bandit18
  • 78' CB550K
« Reply #2 on: January 28, 2012, 08:29:30 PM »
Do I need to get a o ring that is from a carb rebuild pkg or can I use any fuel resistant one of the same size?
« Reply #3 on: January 28, 2012, 08:36:46 PM »
anything same size is ok so long as its impervious to fuel.
Offline Bandit18
  • 78' CB550K
« Reply #4 on: January 28, 2012, 08:48:33 PM »
Thanks guys,this site has great info.
