Author Topic: Oil buzzer  (Read 1661 times)
Offline Sawdust723
  • It ain't illegal if you don't get caught.
Oil buzzer
« on: January 29, 2012, 10:18:02 AM »
I am planning on hooking my turn buzzer into my oil light circuit. It would be kinda cool also because if you forget to turn your key off it would continue to buzz. And when you start your bike it would go on for a sec kinda like a new bike or car. And obviously go off when there is low oil pressure. I think that would be nice because I don't look down too often. Any thoughts from you guys?
1974-77 cb750ish
1971 cb350 twin
Re: Oil buzzer
« Reply #1 on: January 29, 2012, 01:52:21 PM »
Sounds like your the first--have not heard of anyone doing that yet.
72500john
Re: Oil buzzer
« Reply #2 on: January 29, 2012, 05:58:02 PM »
neat idea..as far as on oil pressure loss warning device i dont know if you will be able to hear it criusing down the highway. but for what you have planned for it , it should work well!
Offline Sawdust723
Re: Oil buzzer
« Reply #3 on: January 29, 2012, 06:57:36 PM »
Thanks for the input. As far as hearing it on the hwy I think your right but hey it will still be different
1974-77 cb750ish
1971 cb350 twin
Offline Spanner 1
Re: Oil buzzer
« Reply #4 on: January 29, 2012, 07:06:02 PM »
No Sawdust between your ears dude!... yep, wire the 'buzzer' into the oil pressure switch wire and Bobs-yer-uncle.... may not buzz as loud as with the turn signals tho'.......
bollingball
Re: Oil buzzer
« Reply #5 on: January 29, 2012, 08:24:20 PM »
After you get it to work. Mount it under the seat cover up front ;D ;D That will get your attention.
                                      Ken
Use your horn instead of the buzzer JK :D
Offline Deltarider
Re: Oil buzzer
« Reply #6 on: January 30, 2012, 06:49:50 AM »
http://forums.sohc4.net/index.php?topic=38786.msg402769#msg402769
I used to do that decades ago. When turning on the ignition key the buzzer starts screaming and people may think you're about to start a diesel engine. Warning: you will not hear the buzzer over the riding wind at cruising speeds.
CB500K2-ED Excel black
Offline Sawdust723
Re: Oil buzzer
« Reply #7 on: February 04, 2012, 05:23:51 AM »
Well I did it and it was pretty easy. I might mount it in the back seat for my wife lol. We will see if it stays hooked up it might get annoying. It's kinda louder than I thought. Thanks Guys for your input!!
1974-77 cb750ish
1971 cb350 twin
Re: Oil buzzer
« Reply #8 on: February 04, 2012, 05:41:19 AM »
The first thing I thought was, "That'd annoy the crap outta me", I only had a turn signal buzzer on one bike, my CB750F that I bought new back in the day, and it stayed connected for all of a week before I decided I couldn't stand it any more. But if you like it, I think you should install a set of air horns and connect it to them, and make sure you put your helmet on before you start your bike, you'll need it! Cheers, Terry. ;D
Offline crazypj
  • I'm brill, me
Re: Oil buzzer
« Reply #9 on: February 04, 2012, 07:45:36 AM »
The first thing I thought was, "That'd annoy the crap outta me", I only had a turn signal buzzer on one bike, my CB750F that I bought new back in the day, and it stayed connected for all of a week before I decided I couldn't stand it any more. Cheers, Terry. ;D
+1
Offline Sawdust723
Re: Oil buzzer
« Reply #10 on: February 04, 2012, 10:11:48 AM »
Air horns that had me laughing my butt off!!!
1974-77 cb750ish
1971 cb350 twin
Re: Oil buzzer
« Reply #11 on: February 04, 2012, 07:53:12 PM »
the little truck i drive at work has an external reversing beeper we had to put fibrous adhesive tape over to tone it down,,it was the beeper from hell!,,trouble is it also has a quieter one factory fitted behind the dash in the cab some where,,i cant bloody find it,i even brought a decent flash light in from home and had the beeper activated,the fuse stops both of them so thats not an option,its fkcing annoying,,ill kill it one day when i get my hands on it,you can always hook you oil switch to your ignition,so itll take a bit of a crank to fire up but kill the engine if the oil pressure goes nil,lots of late cars have this wired to the fuel pump,,i dont like it,the idea is in a crash the fuel pump stops so long as the engine stalls.
« Last Edit: February 04, 2012, 07:56:43 PM by dave500 »
Offline verslagen1
Re: Oil buzzer
« Reply #12 on: February 05, 2012, 10:30:06 AM »
wire a resister in series with the fuse to reduce the voltage to the beepers.
'88 Savage Daily rider
'72 CB500 Garage find
72500john
Re: Oil buzzer
« Reply #13 on: February 05, 2012, 05:26:02 PM »
come to think of it my dads 80s something bmw had something like this. very annoying until he started it. guess it gets your attention. guess he would be able to hear a low oil presure warning since he could hear his  radio  while riding.
