Author Topic: Question about the actual magneto on a ARD mag  (Read 3160 times)
Offline jaguar
« on: January 30, 2012, 04:28:07 am »
I thought that it was talked about a bit here but cant seem to find the info.
What is the info/part number/application of the mag used on a ARD?  I have a chance to get an early drive set up that is complete save the actual magneto.  I seem to remember guys talking about tractor fairbanks or morris mags and using them.  is this true?
I would assume that things like shaft length would come into play.  also alot of the ones i see are single cylinders, can the cap be changed to run four?
http://www.ebay.com/itm/Mercury-outboard-Fairbanks-magneto-racing-pleasure-/110816895889?hash=item19cd33a391&item=110816895889&pt=Boat_Parts_Accessories_Gear&vxp=mtr#ht_500wt_1156
http://www.ebay.com/itm/Fairbanks-Morse-magneto-ignition-generator-CW-type-30-mfd-Y-73-8-/220928770194?hash=item3370618092&item=220928770194&pt=Other_Vehicle_Parts&vxp=mtr#ht_500wt_1156
My thought was that i could take the drive and a $200 mag and have a nice set up with out spending a grand for a used set up
thanks so much for any help
Offline Jim F
  • go baby go
Re: Question about the actual magneto on a ARD mag
« Reply #1 on: January 30, 2012, 05:46:12 am »
it looks like to could  take the housing of the ARD with the drive pulleys and you should be set
But thats a big assumption
I had one but didn't have all the parts to make it work
The shop that I used, and Steve knows all about these old systems is
Mainely Magnetos
127 Cyr Road
Cross Lake Twp, Maine 04779
1-207-834-7309
Steve & Debbie Belanger
Good folks
Good luck
Jim
« Last Edit: January 31, 2012, 09:03:27 pm by Jim F »
2002 RC51 1000 (SP2)
1983 GS1100EC Suzuki
1992 KTM500 2 stroke
1975 CB750/836 Honda
1978 GS750/840 Suzuki
Offline sohc boy
« Reply #2 on: January 30, 2012, 03:03:52 pm »
 Jaguar , i have one , Fairbanks Morse (used on some 4 cyl  tractors ) dont know part number of em ,(nothing on em ) just that it has short tapered shaft,an pulley to suit
« Last Edit: January 30, 2012, 03:12:58 pm by sohc boy »
i live by the voice inside my head
  • Moderator
« Reply #3 on: January 30, 2012, 03:22:01 pm »
You must be able to do a search, there has been a lot of torque on here about them. ;D ;D ;D ;D
Sam. ;)
Offline buttcan
« Reply #4 on: January 31, 2012, 06:56:11 pm »
Hey Jaguar. I have heard discussion that it may be a FM-J4B or a FM-K4B magneto. I do know that fairbanks was not the only one used though. If I have a chance I'll try to pull mine tomorrow and give it a lookey see and let you know what I find. Need to know myself cause I broke the plastic cover.
Inevitability: The realization that no matter how hard you try you'll never be as cool as a bull riding monkey...
Offline piute
  • Piute
  • TRICK OR TREAT...B....es
« Reply #5 on: January 31, 2012, 07:23:44 pm »
V.W. ?
Ride to live Live for Jesus
1977 750 F2
« Reply #6 on: January 31, 2012, 09:34:19 pm »
VW was used on some other drives. The midget car guys used one that drove a VW or volvo dist/mag  and a hilborn fuel pump to drive the FI.  It stuck out vertical from the point area.
If you love it, set it free, if it stays it's probably one of my 750's.
Offline Big Jay
    • CBRzone
« Reply #7 on: January 31, 2012, 09:47:49 pm »
The old style was a Fairbanks Morse used on Ford tractors
« Reply #8 on: January 31, 2012, 10:01:05 pm »
I think my old lincoln pipeliner welder had one on it's continental engine too. worked great until a shop mechanic changed out the ignition switch and fed it 12V.
Offline jaguar
« Reply #9 on: February 02, 2012, 06:25:20 am »
I have searched around here and never gotten a final answer.
I should have the set up minus the mag this weekend and should be able to start taking pictures and measurements.
It seems that a few people have these and could use a mag to make everything work.
Offline Big Jay
    • CBRzone
« Reply #10 on: February 02, 2012, 10:04:37 pm »
You could check with http://www.huntmagnetos.com/  for Fairbanks Morse parts
Offline BLUE71TURBO
« Reply #11 on: February 03, 2012, 01:24:42 pm »
 Any and everything you will need for the older magneto's bar none !
   http://www.magnetoparts.com/index.html
 And if you need belts and pulley's,  this is the best place to get them............
    http://shop.polybelt.com/XL025-1-4-Wide-Belt_c45.htm
« Last Edit: February 03, 2012, 01:33:53 pm by BLUE71TURBO »
Offline buttcan
« Reply #12 on: February 05, 2012, 06:13:36 pm »
Hey I wasn't able to find a model number on that mag. I know its a FM cause it us marked on the cover but that is all I found.
