Author Topic: Gas tank trim?  (Read 1387 times)
Offline messeduptriple
Gas tank trim?
« on: January 31, 2012, 07:30:00 AM »
Ok so my tank has been cleaned and ready for powdercoating finally. I had to take off that aluminum or cheap tank liner...it basically snapped when trying to pull them off. Do they sell these seperate and if so where? And what is the specific name of these?
* I guess do I really need them after a custom painting?
Sent from my PC36100 using Tapatalk
« Last Edit: January 31, 2012, 07:34:59 AM by messeduptriple »
Offline Really?
Re: Gas tank liner ?
« Reply #1 on: January 31, 2012, 07:31:43 AM »
Tank liner or the tank trim on the bottom of the tank?
The Wife's Bike - 750K5
The Kid's Bike - 750K3
« Reply #2 on: January 31, 2012, 07:34:25 AM »
Yea..the tank trim...
Offline toytuff
  • "watching the pinheads"
Re: Gas tank trim?
« Reply #3 on: January 31, 2012, 07:41:42 AM »
Very expensive if you can find OEM. For my 77 K it was over $250.00 plus clips.
What bike? I ordered these from David Silver for the 77/78 tank. Brushed finish but look sharp. Not going to use them.
tt
« Reply #4 on: January 31, 2012, 07:45:47 AM »
76 550
Re: Gas tank trim?
« Reply #5 on: January 31, 2012, 07:50:19 AM »
If your not hung up on stock there are various types of chrome looking door trim that can slip over the lip,or at least on 750 tanks,to give a finished look to that area.
Re: Gas tank trim?
« Reply #6 on: January 31, 2012, 07:56:18 AM »
Yeah.
To answer your (OP) question, assuming a CB750, if your paint job so allows, you can leave those trim strips off. Bend the tabs back out of the way so they don't show. I had mine removed altogether.
Offline toytuff
« Reply #7 on: January 31, 2012, 07:58:20 AM »
76 550
I might have one from a 78 550. If I remember it was not very good. Fresh paint would look good with fresh molding.
I'll dig around and see if I can find it.
tt
Offline IndyFour
Re: Gas tank trim?
« Reply #8 on: January 31, 2012, 08:15:40 AM »
Mine did the same thing when I took off the original....just snapped into pieces.  After my repaint, I found this 1/4" stick-on chrome that works well.  Stuff is cheap and seems to hold up well.  I think it was $15 for 20ft or something like that.  Did the tank, the seat (sticks fine to my aftermarket vinyl seat cover) and then had enough to do the tank again when it was repainted a second time (long story).  While it doesn't cover the tank edge (i.e. wrap around the edge), it fills the space around the bottom and front perfectly and is very flexible.  Like someone mentioned above, you might be able to find that auto door edge stuff that's wide enough to work as well.  Same idea.
I think I found this at Meijer or Walmart.  Probably at the auto parts store as well.
1974 CB550K
2000 VFR800FIY
__________________
Indianapolis, Indiana
Offline toytuff
Re: Gas tank trim?
« Reply #9 on: January 31, 2012, 08:21:11 AM »
The one I have is pretty shot.
tt
