Author Topic: Float adjustment without measuring?  (Read 1322 times)
Offline lucky
« on: January 31, 2012, 02:49:05 PM »
OK....I have made another discovery.
On the 1978 CB750 PD carbs with accelerator pump the floats are rectangular plastic.
The Clymer's manual does NOT show this style at all in chapter 3 or in chapter 6.
The measurement is 14.5mm above the carb body to the top of the float when the carb is upside down. OR .570 thousandths of an inch.
But you do not even need to measure. Just place a straight edge over the top of the idle jet (push in style) and you will see that when the float is .570 above the carb body surface that the top of the float and slow jet are the same height,when the carb is upside down. Do not push down on the floats to make this happen.
You do not have to worry about the float pressing on the float spring. The spring is so stiff that you would have to push it down with your finger to make a difference.
Bonus tip:
Check to see that the float bowl drains on the inside carb and the outside carb on each side of the bike point outwards.
I have seen several bikes now where the #1 and #4 float bowls are mixed up and point the wrong direction on the outside carb.
The float bowls on those two carbs will interchange.
« Last Edit: January 31, 2012, 03:22:34 PM by lucky »
Offline DWS
  • Treat others as you would like to be treated .
Re: Float adjustment without measuring?
« Reply #1 on: August 24, 2012, 09:56:53 PM »
very nice tip that just save me some money, now i don't have to buy a float gauge. thanks :P
Always looking for friends
78 Honda CB 750 F3 Restoring now
BSA MX 50 Next
BSA b50T Parts
Yamaha 1980 Virago 750 thinking about restoring maybe parting
Offline lucky
« Reply #2 on: August 31, 2012, 11:58:26 PM »
You are welcome. You are the first person to thank me.
By the way it is .570 thousandths . + or -
Offline toohai2
    • Hai Designs
« Reply #3 on: October 14, 2012, 01:18:14 AM »
+1
I am giving thanks also, Lucky.
I bought the metal float height tool, but I used your method instead of waiting for it to arrive for my carb rebuild.
Sean from Missouri
1978 CB750K8
Offline markb
  • When I finish my current project I might be an
« Reply #4 on: October 15, 2012, 09:07:11 AM »
Just to be nitpicky it's actually 570 thousandths or .570.  ;)
1969 CB750 sandcast #97 current project Restoration thread link
1969 CB750 sandcast #1553 next project
1969 CB750 sandcast #1990 next project after that
1969 CB750 sandcast #5383 Restoration thread link
1970 CB750 K0 restored
2010 H-D Tri Glide Ultra Classic (Huh?)
Motorcycle Project Banner Ad
Honda
