Author Topic: CB550 Gulf road race build 592cc  (Read 78967 times)
Offline kc 74 550
  • "can we fix it?"................. 'nope it's Fuc&%
Re: CB550 Gulf road race build 592cc
« Reply #125 on: September 15, 2013, 01:59:48 AM »
subscribed.
nice work on the bike!
Offline Bankerdanny
  • Endeavor to persevere
« Reply #126 on: September 16, 2013, 09:25:32 AM »
You hope to assemble an engine, install it in the bike, put the carbs back on, hook up the electrical and fuel systems and get it started and have the carbs sorted in 14 days?
I hope you weren't planning on much sleep my friend.
Offline Dimitri13
  • 1974 CB550K
« Reply #127 on: September 16, 2013, 09:38:28 AM »
Tall order, but I only work weekends right now, so I have 10 solid days with several people to help if needed. The wiring harness is in tact, just needs bolting on.
If not I have the Vette or ranchero as backup.
« Reply #128 on: September 16, 2013, 06:56:06 PM »
Thought the cases were together by now?
Offline Dimitri13
  • 1974 CB550K
« Reply #129 on: September 16, 2013, 09:03:44 PM »
Yeah me too...
Offline Dimitri13
  • 1974 CB550K
« Reply #130 on: September 18, 2013, 10:18:00 PM »
Finally got the cases together. Missing two M6x40 flanged bolts though. Turned it right side up, messed with the shift drum, and a pin fell out. I think I forgot to put a clip in to keep that pin in. Not sure where it is or what it looks like.
« Reply #131 on: September 20, 2013, 04:33:53 AM »
Looks like a small hitch pin. NLA from Honda too.
Offline Dimitri13
  • 1974 CB550K
« Reply #132 on: September 20, 2013, 05:19:39 AM »
Went down to the hardware store and got a hitch pin. Perfect diameter and seems strong enough. It was a bit too long so I bent it over like a cotter pin.
Getting closer.
That weight is JUST the cases and bottom end internals. Lightened crank, rods, main/counter shafts, shift drum, shift forks, primary shaft, starter clutch. No alternator, points, clutch, shift mechanism, etc. I'll get a final dry weight with the starter once I get it all together.
Next hangup is the shifter mechanism. I'm not sure if I have all the parts. This is what I have, it's laid out roughly how it would be installed:
This is what someone posted on the forum at some point. It's a 550, but the mechanism looks different.
The only noticeable difference is there isn't a second spring on the right side. Is it just a later design? My parts are from my 74.
Oh, and nothing goes into the threads of the shaft that holds the shift forks, right (visible behind the left side of the top bearing retainer)?
And another question: My powdercoater didn't mask off a few gasket surfaces, most notably the clutch cover mating surface on the case, and the oil pan mating surface on the oil pan side. Should I sand down the powdercoating on all gasket surfaces?
« Reply #133 on: September 20, 2013, 01:47:07 PM »
Your mechanism is indeed early 550. Nothing threads into the shift fork shaft, it's kept in place by that retainer. Make sure the retainer is straight, often they are bent at the end that secures the shaft.  For sure remove the powder paint from the gasket surfaces.
Offline Dimitri13
  • 1974 CB550K
« Reply #134 on: September 20, 2013, 03:54:02 PM »
Thanks Brent. It went together alright. I'll remove all the extra powdercoating.
Offline Dimitri13
  • 1974 CB550K
« Reply #135 on: October 11, 2013, 10:02:49 AM »
Haven't posted in a while and I haven't done much work. Been working way too much.
I did get the pistons installed, as well as some of the extra powdercoating removed. It's hard though, all I really have are grinding discs, and they get clogged up real fast. Anyone have a tip to remove the powdercoating? I still have several pieces to go.
« Reply #136 on: October 11, 2013, 04:48:56 PM »
Superb!
« Reply #137 on: October 11, 2013, 05:58:48 PM »
Superb!
+1....looks awesome
Offline Dimitri13
  • 1974 CB550K
« Reply #138 on: November 03, 2013, 10:35:54 PM »
Slow progress... Installed the APE heavy duty studs. $4 ring compressors ready to drop the cylinders on. Can't yet though, I need to redo the cam chain master link. Brent (bwaller) mentioned that it might be difficult to rivet it, and he was right.
Finished grinding all the excess powder coating. Got a grinding disc from the powdercoater that ate right through it (seen in bottom right), then buffed out the rough stuff with a worn disc. Everything is nice and shiny waiting to be mated to gaskets and other parts.
« Reply #139 on: November 05, 2013, 06:24:13 PM »
Do you plan to use a little sealant with the gaskets?
Offline Dimitri13
  • 1974 CB550K
« Reply #140 on: November 05, 2013, 07:10:35 PM »
Which gaskets? You mean the o rings on the cylinders, or the base and head gaskets? If the latter, I use copper spray basket.
« Reply #141 on: November 05, 2013, 07:14:35 PM »
Yes, base and head.  Copper spray sounds perfect.  A buddy used none recently and suffered a leak soon after.
Offline Dimitri13
  • 1974 CB550K
« Reply #142 on: November 06, 2013, 06:57:35 PM »
Thanks Steve, I was debating on whether I wanted to use any or not. After doing some searching, I decided to.
____________________
After having troubles riveting my master link, I decided to do some research, and found that the master link I had was a press-fit, not meant to be riveted. You can tell because the posts of the link are solid and the same color.
I ordered 5 master links from Z1, and one I miraculously got a rivet style master link. You can tell because the ends of the posts have dimples and are a different color.
Refer to the images.
« Reply #143 on: November 06, 2013, 07:33:57 PM »
Yes I can see some of those would be tough to rivot!
« Reply #144 on: November 07, 2013, 05:25:50 AM »
That is interesting Jaymie... ???
Offline Dimitri13
  • 1974 CB550K
« Reply #145 on: November 14, 2013, 12:45:17 PM »
Finally made more progress.
The oil is there to lube the cylinder walls and to check for leakdown I guess.
Offline Doctor_D
« Reply #146 on: November 14, 2013, 02:27:16 PM »
Glad to see that it's coming along...
You're not going to know much about your leakdown until the rings have seated, so don't take anything from the speed at which that oil drains.
Not that you want my unsolicited advice, but since we're talking about rings and oil... for best ring seating, you want nearly dry cylinders (I use Total Seal Quick Seat on clean dry bores), and you want to run it under load and at high cylinder pressures pretty quickly after initial start-up.  Lots of oil will only delay the break-in.  My advice is to pull your cylinders and follow the instructions below.
Here's how I do it: After honing, wash your bores with warm soapy water, dry them completely then apply some wd-40 to a lint-free cloth.  Wipe the cylinders out with clean cloths until they come out as white as they went in.  Apply Quick Seat per the instructions, then it's heat-cycle, retorque, oil change, restart to check for timing and carb synch -- then right on to the dyno (or 3rd gear hill-pulls).
We do lots of motors, and we do them all this way.
Take care,
David
1978 CX500
1971 Norton Commando
« Reply #147 on: November 14, 2013, 05:00:09 PM »
Good advice. I follow a similar procedure and it hasn't failed to create good ring seal.
Offline Dimitri13
  • 1974 CB550K
« Reply #148 on: November 14, 2013, 08:41:19 PM »
Thanks David and Brent.
I had no idea really. This is my first full build. I'll see if I can find quick seat or similar on island. The leakdown comment wasn't made in seriousness, just talking out of nowhere.
Offline Dimitri13
  • 1974 CB550K
« Reply #149 on: November 15, 2013, 12:55:04 AM »
Got the rotor nut on the end of the crank. SO easy to turn now. Very hard to turn the engine with the cam chain ;)
Well I cleaned up the cylinders. Installed the cam chain tensioner, but I'm not sure if I should replace the blades... ignore the PBR. It's cheap.
