Author Topic: CB550 Gulf road race build 592cc  (Read 78996 times)
Online Stev-o
Re: CB550 Gulf road race build 592cc
« Reply #250 on: April 24, 2014, 07:41:18 PM »
Ah I see. So it's because I live in Hawaii then?
Bingo. That and you have da kine bike, braddah.
But no Ferrari
Offline calj737
  • I refuse...
« Reply #251 on: April 24, 2014, 07:47:07 PM »
Tue. But Magnum didn't have a CB550 in Gulf livery!
Offline grcamna2
« Reply #252 on: April 24, 2014, 07:57:22 PM »
When I've seen that show I never remember seeing Magnum w/ any local Hawaiian  women ? only haole wahine's.
« Reply #253 on: April 24, 2014, 09:26:32 PM »
I guess Magnum missed out on the Kama'ainas.
Offline Dimitri13
  • 1974 CB550K
« Reply #254 on: April 25, 2014, 12:12:41 AM »
Indeed he did.
Gonna go talk to a few painters tomorrow. Hopefully they can help me out.
Offline Carver
« Reply #255 on: April 28, 2014, 01:36:52 PM »
I'm going to need you to uhhhh, finish building this so I can see the end result, please? ;D
Cb 750 k3
Cb 450 dohc k4
Offline Bankerdanny
  • Endeavor to persevere
« Reply #256 on: May 30, 2014, 10:20:58 AM »
Ok Dimitri, it's been over a month. Anything new?
Online Stev-o
« Reply #257 on: May 31, 2014, 10:17:04 AM »
+1.  Stalled project?
Offline KrautKoffin
« Reply #258 on: June 26, 2014, 09:30:35 PM »
Herro?
74 cb550
I now have Beastie Boys "Sabotage" stuck in my head after seeing your avatar.
Offline Dimitri13
  • 1974 CB550K
« Reply #259 on: June 27, 2014, 04:51:33 PM »
Been working a lot. Issues one thing after another. This one was the last straw. Taking a break to cool down (and build up some funds). I still have too much to do. Need spokes and tires just to get it rolling. Need cables. Need a seat, upholstery, paint. Need several gauge parts. Need dual disc parts. Need need need. All costs money.
Been doing photography, both film and digital, to occupy my spare time.
Online Stev-o
« Reply #260 on: June 27, 2014, 04:54:04 PM »
stripped?
Offline Dimitri13
  • 1974 CB550K
« Reply #261 on: June 27, 2014, 05:11:28 PM »
Yes.
« Reply #262 on: June 27, 2014, 05:34:14 PM »
All cost money. You got that right.
Q: How fast do you want it to go?
A: How much do you want to spend?
Offline SF
  • I burn gas very well
« Reply #263 on: June 29, 2014, 06:00:17 AM »
You can beat on her when she's done! Can you chase the threads?
92 wr250 sold
98 zx6r sold
04 zx10r
73 cb350 twin
75 cb550f
75 cb550f
72 r5c
rgid springer bobber project
« Reply #264 on: June 29, 2014, 07:09:49 AM »
Unfortunately I have run into that problem too. It happened after bead blasting a 750 cover. Bead gets stuck in those large thread. I mean I cleaned it but you have to get in there with a toothbrush, bronze gun brushes etc and plaenty of brake cleaner and compressed air. The caps screwed in OK but jammed like hell when I tried to remove them (which was right after I finished painting it) ::)
Offline calj737
  • I refuse...
« Reply #265 on: June 29, 2014, 10:05:13 AM »
I use a Dremel with a plastic brush wheel on it. Chase the threads of all the tappet covers and clean like hell.
I like blasting cases and covers, but you've GOT to clean like hell afterwards for insurance.
Offline Dimitri13
  • 1974 CB550K
« Reply #266 on: June 29, 2014, 10:21:11 AM »
I have a feeling it was powdercoat. I blame myself. I should've cleaned the threads before I put it on. Once it was on I was too lazy to take it off and clean them.
Offline Trad
« Reply #267 on: June 29, 2014, 11:17:01 AM »
Such a bummer. I have several extra valve covers if you are in need of one.
74 CB550 Build: NOS-GUTTED-OEMplus-HOLDTRUE
http://forums.sohc4.net/index.php/topic,130575.0.html
Offline Dimitri13
  • 1974 CB550K
« Reply #268 on: June 29, 2014, 11:31:19 AM »
If I can't fix it within reason, I'll be looking for a 77-78 cover if you have.
Offline SF
« Reply #269 on: August 09, 2014, 06:12:27 AM »
Dimitri how you making out with that cover?
Sent from my iPad using Tapatalk
92 wr250 sold
98 zx6r sold
04 zx10r
73 cb350 twin
75 cb550f
75 cb550f
72 r5c
Offline Dimitri13
  • 1974 CB550K
« Reply #270 on: August 09, 2014, 06:18:04 AM »
Managed to get it mostly un#$%*ed.
« Reply #271 on: August 09, 2014, 01:57:10 PM »
 ;D
The threads don't need to be pretty, just hold the cap.
Offline Dimitri13
  • 1974 CB550K
« Reply #272 on: August 09, 2014, 02:25:48 PM »
Been real busy with work, my woman, photography, and bowling. Not much time to get in the garage. Will find some time though. Also working on my other two projects. Vette needs some attention. Ranchero needs some suspension worked. Went curb hopping a couple weeks back. Bent the LCA, destroyed the tie rods, bent a wheel, and shredded a tire. Tires and wheel replaced, waiting on other suspension parts. Also working on timing/ignition issues. Have a cheap quiet gear drive coming, timing chain stretched 15°+. Waiting on a replacement vacuum advance, the one I ordered already was too big.
Offline Dimitri13
  • 1974 CB550K
« Reply #273 on: August 10, 2014, 03:28:23 PM »
Adjusted the valves. Couldn't find my M5x.8 tap. Found it. Had to clean out the threads of one of the points plate mount threads.
I think I'm going to pull out the harness today or tomorrow and see what I can do with it. It was rebuilt last year, thanks to my dad. One day I'll have a minimal harness, simplified with one of those fuse block thingies.
Offline SF
« Reply #274 on: November 09, 2014, 06:36:00 AM »
How's the project coming along?
92 wr250 sold
98 zx6r sold
04 zx10r
73 cb350 twin
75 cb550f
75 cb550f
72 r5c
