Author Topic: CB500K restoration and re-styling. RED FRAME  (Read 16833 times)
Offline lucky
Re: CB500K restoration and re-styling
« Reply #100 on: March 31, 2012, 06:57:49 AM »
With a sandblasted finish it will get dirty and dark grey color. Dirt will really stick to it.
No way to clean it. Also corrosion canstart.
I would paint it with engine paint.
Are you sure? There are a lot of non pinted engine, also in Honda. most of Honda scooters has no paint in the transmission case and crankcase. If you do not take care, white dots of corrosion may appear but only if this bikes rides in salted roads or in seaside areas. I love my bike and I will care it.
[/quote]
Those "white dots" is chlorides of aluminum. Corrosion.
All of the Honda engine cases come with a coating on them.
Offline lucky
Re: CB500K restoration and re-styling. RED FRAME
« Reply #101 on: March 31, 2012, 07:13:02 AM »
WARNING!
That gap between the engine and the frame is a problem!
You cannot just tighten up big gaps because it puts a lot of stress on the aluminum engine case. use shims if you have to.
Loosen the bolts on the frame and get that engine mount plate up against the engine mount.
Then put washers between the frame and the mount plate. If you have to get longer bolts! That is too large of a space to just draw it up. You are lucky the engine casting has not cracked.
Very nice job so far.
« Last Edit: March 31, 2012, 07:18:55 AM by lucky »
Offline Lorbaez
  • CB Power
« Reply #102 on: March 31, 2012, 11:47:42 AM »
WARNING!
Thaks for the suggestion, I will loose the bolts and re check again, if necessary I will put washers.
Thanks Lucky
Regarding Coat for the engine, are you sure that all engines are coated? I have an engine from a Scooter in front of me and I can not see coat on it.
CB500K Re Styling
[http://forums.sohc4.net/index.php?topic=101860.0]
Offline Lorbaez
  • CB Power
« Reply #103 on: April 03, 2012, 02:22:13 PM »
WARNING!
Then put washers between the frame and the mount plate. If you have to get longer bolts! That is too large of a space to just draw it up. You are lucky the engine casting has not cracked.m
Tons of thanks. I did what you suggest me. I used 5mm washers betwen plate and frame. Now it is perfect.
« Last Edit: April 04, 2012, 10:39:00 AM by Lorbaez »
CB500K Re Styling
Offline Lorbaez
  • CB Power
« Reply #104 on: April 04, 2012, 12:37:34 PM »
before and after
« Last Edit: April 04, 2012, 02:08:33 PM by Lorbaez »
CB500K Re Styling
Offline Lorbaez
  • CB Power
« Reply #105 on: April 04, 2012, 12:38:48 PM »
some details
CB500K Re Styling
Offline Lorbaez
  • CB Power
« Reply #106 on: April 04, 2012, 12:40:14 PM »
some more
CB500K Re Styling
Offline Mcwilliams570
« Reply #107 on: April 04, 2012, 01:47:45 PM »
Looks great man job well done..
Matt
My CB550 project http://forums.sohc4.net/index.php?topic=101182.0
Project UFB Cb550 http://forums.sohc4.net/index.php?topic=112143.0
Like a 10 dollar hooker on Friday night its going to be ridden.
1974 cb550
1975 cb550
2005 vmax
2009 vmax-sold
1981 gl500i
Offline Lorbaez
  • CB Power
« Reply #108 on: April 05, 2012, 01:36:04 AM »
Matt
Thanks man,
your project is onging also great.
CB500K Re Styling
Offline lucky
« Reply #109 on: April 08, 2012, 10:17:06 AM »
This is the owner of broken part
Th PO must have really stomped down with their big cowboy boot on that gear!! WOW.
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
« Reply #110 on: April 08, 2012, 03:51:41 PM »
Unpainted cases will require much more maintenance to keep clean over time.  The aluminum will be far more susceptible to oxidation, and discoloration.  Some paint colors match the raw cases almost perfectly.
Very nice work so far!
Offline Lorbaez
  • CB Power
« Reply #111 on: April 09, 2012, 05:30:25 AM »
I agree with you, but:
One of my friends tunned a Yamaha SRX600 12 years ago. He didn't paint nor case nor cylinder and still looks perfect. It's clear that it need some more care than painted but finish is very special.
I hope in 10 years I will be able to re confirm my theory.
CB500K Re Styling
Offline Lorbaez
  • CB Power
« Reply #112 on: April 12, 2012, 03:02:30 PM »
Last days I've been working on most important part: Adjustments.
they are not really visible but they are very important to enjoy riding (not only cleaning the bike).
After first start I noticed some fuel leakage from float chamber breathers. When I worked with carburetors I didn't pay attention since bike was runniong OK before engine removal.
Once checked I found many parts out of service limits.
I ordered new floats, float valves, slow and main jets and of course new o rings.
You can see cone wear comparing old float valves with new one in the midle.
CB500K Re Styling
Offline OneWheelDrive
  • A journey of 1000 miles starts with your first carb overhaul.
« Reply #113 on: April 12, 2012, 04:32:56 PM »
Where did you get that seat!?
1975 CB550 cafe
1971 CB500 stocker
2008 Ducati Hypermotard 1100S *sold*
1973 CB350F *sold*
1975 CB550K Project "Keeper" *sold*
2010 Ducati Monster S4RS *sold*
1976 CB360T *sold*
1974 CB550K *sold*
1973 CB750K *sold*
1978 CB550K *sold*
2007 Vespa LX150 *sold*
Offline Greggo
  • Somebody's
« Reply #114 on: April 12, 2012, 08:32:30 PM »
+1.  Me Wantee.
Offline Lorbaez
  • CB Power
« Reply #115 on: April 15, 2012, 11:43:49 AM »
This seat has been restored by an specialist in Barcelona city called Motosillin.
http://www.motosillin.com/
Very nice man and a really good job
CB500K Re Styling
Offline Lorbaez
  • CB Power
« Reply #116 on: June 10, 2012, 11:24:07 AM »
I boys,
Long time since last entry. I been working on my bike, and it is ready. Today a classic meeting has been organized in Barcelona, it has been a nice day to show my bike.
The main problem with Spanish meeting is that most of people only restore old Spanish brand bikes, and they hate Japan bikes. They consider that Japan brands killed Spanish products susch OSSA, Montesa or bultaco.
In any case I'm proud of my bike, it looks fantastic.
CB500K Re Styling
Offline Greggo
  • Somebody's
« Reply #117 on: June 10, 2012, 03:29:32 PM »
It does look fantastic.  Did you have an original Guilari seat for him to restore, or did he do that from the original Honda pan?
Offline Lorbaez
  • CB Power
« Reply #118 on: June 11, 2012, 10:21:09 AM »
[/quote]
I had an original guilari seat. He just restored it. I do not have any picture of the seat before restoration.
CB500K Re Styling
Offline lucky
« Reply #119 on: June 14, 2012, 06:39:39 PM »
The engine vibrations cause those early model metal float valves to get out of round and a groove on the bevel face. that is why Honda went to rubber tip needles.
