Author Topic: CB500K restoration and re-styling. RED FRAME  (Read 18569 times)
Offline LesterPiglet
  • 1977 CB550F2
Re: CB500K restoration and re-styling
« Reply #25 on: February 07, 2012, 02:36:53 PM »
I prefer the unpainted look. I also enjoy polishing alloy.    ;D
Offline lucky
« Reply #26 on: February 07, 2012, 02:56:49 PM »
Shift forks are OK, no blue color and within spec.
Thats good!
Offline lucky
« Reply #27 on: February 07, 2012, 03:03:14 PM »
These are the cylinders once machined, one more time I'm really happy with the job done.
Did you have to get oversize pistons?
.020( .508mm) or .040(1.016mm) thousandths  over?
Offline lucky
« Reply #28 on: February 07, 2012, 03:05:49 PM »
I decided to sandblast all the engine, but I don't pint it.
Do you have experience with non pinted crankcase?
I asume that colour will become dark after some time and I know that this finish will need all my care to mantain it in perfect condition but I love colour and finish of "nude" cast.
With a sandblasted finish it will get dirty and dark grey color. Dirt will really stick to it.
No way to clean it. Also corrosion canstart.
I would paint it with engine paint.
BTW....The driver gets the same prison sentence as the robber, and the driver can also still get shot. The robbers usually shoot the driver and split his share.
Then the drivers girl friend turns in all of them to the cops.
Then the girlfriend of the driver and the girlfriends of the robbers get investigated by the police because the police know they have the money then they go to jail too. Better to just get a job and be honest in the long run.
« Last Edit: February 07, 2012, 03:13:07 PM by lucky »
Offline Lorbaez
  • CB Power
« Reply #29 on: February 08, 2012, 01:52:39 PM »
I have +0.5 mm pistons.
CB500K Re Styling
[http://forums.sohc4.net/index.php?topic=101860.0]
Offline Lorbaez
  • CB Power
« Reply #30 on: February 08, 2012, 01:58:29 PM »
[/quote]
Are you sure? There are a lot of non pinted engine, also in Honda. most of Honda scooters has no paint in the transmission case and crankcase. If you do not take care, white dots of corrosion may appear but only if this bikes rides in salted roads or in seaside areas. I love my bike and I will care it.
CB500K Re Styling
Offline Lorbaez
  • CB Power
« Reply #31 on: February 08, 2012, 02:08:23 PM »
As you can see in first picture, my bike was OK but nor 100% original, exhaust system is aftermarket, rear shocks are Marzzocchi, and some parts are from a CB550K not CB500K. It won’t be a “museum” motorcycle so I want to be free to install modern brakes or front fork if needed.
These are the reasons why I decided to redesign it with new colors and some special parts. One of the parts that will have different finish is the cylinder block, I painted in black.
Engine side covers will be mirror polished, engine supports, battery plate, electrics plate will be chromed.
CB500K Re Styling
Offline Lorbaez
  • CB Power
« Reply #32 on: February 08, 2012, 02:18:03 PM »
But now it's time for carburetors. If you see them installed on the bike, they are Ok. But once you remove them, you can see how dirt they are, especially between number 2 and 3. It is a good opportunity to install new o-rings, gaskets and tubes.
CB500K Re Styling
Offline Lorbaez
  • CB Power
« Reply #33 on: February 08, 2012, 02:19:09 PM »
some help is wellcome
CB500K Re Styling
Offline Lorbaez
  • CB Power
« Reply #34 on: February 08, 2012, 02:21:01 PM »
Some steps of the process.
CB500K Re Styling
Offline Lorbaez
  • CB Power
« Reply #35 on: February 09, 2012, 12:53:42 PM »
It's time to assembly the engine:
This is the list of new parts:
5th gear of countershaft
 Bearings (main shaft and countershaft)
All Gear washes and circlip
Main shaft and countershaft oil seals
Primary shaft bearings
Crankshaft bearing: Cylinder 1,2 and 4 brown color, cylinder 2 green color
Clutch friction disc and metallic, also new springs.
New pistons
All gaskets are new.
All bolts are new. All except the bolt who fix drum ref. 2445-266-020. Impossible to find.
Chains are OK, and also chain tensioner.
CB500K Re Styling
Offline Lorbaez
  • CB Power
« Reply #36 on: February 09, 2012, 12:55:23 PM »
Some pictures
CB500K Re Styling
Offline Mcwilliams570
« Reply #37 on: February 09, 2012, 12:58:56 PM »
Looking good so far.
Matt
My CB550 project http://forums.sohc4.net/index.php?topic=101182.0
Project UFB Cb550 http://forums.sohc4.net/index.php?topic=112143.0
Like a 10 dollar hooker on Friday night its going to be ridden.
1974 cb550
1975 cb550
2005 vmax
2009 vmax-sold
1981 gl500i
Offline Lorbaez
  • CB Power
« Reply #38 on: February 09, 2012, 01:46:04 PM »
Matt
Thanks man. It's great to see that somebody is interested.
CB500K Re Styling
Offline Lorbaez
  • CB Power
« Reply #39 on: February 09, 2012, 01:47:13 PM »
Some more pictures
CB500K Re Styling
Offline Strapman
« Reply #40 on: February 09, 2012, 05:33:38 PM »
Nice work!!!! I recently picked up a 72 CB500 K1 with 1200 original miles, went thru all the standard stuff re carbs, valves/tappets, points, rebuilt front brake cyclinder chased a damn electrical short for days!!! Dissambled all and cleaned, except the engine. Thinking about pulling engine soon and polishing engine covers (clutch side/points side)...was the philips heads screws holding engine covers together a #$%* to remove?
Offline Lorbaez
  • CB Power
« Reply #41 on: February 10, 2012, 11:18:28 AM »
Thanks Strapman.
I agree, philps head screws are a big #$%*. I absolutely prefer allen head bolts. But this time I use original screws so some of them are Philips head.
CB500K Re Styling
Offline Lorbaez
  • CB Power
« Reply #42 on: February 10, 2012, 11:21:51 AM »
I show you a picture of the cylinder head with new original screws and bolts
CB500K Re Styling
Offline Lorbaez
  • CB Power
« Reply #43 on: February 10, 2012, 11:45:14 AM »
2 weeks ago I received parts from painter.
Colors are based on honda original colours:
Red: Is the same as CB1300 frame 2005 year model
White: VFR1200F 2010 year model
black: NT700V  2010 Year model
I coudn't resist to make a quick assembly
CB500K Re Styling
Offline Lorbaez
  • CB Power
Re: CB500K restoration and re-styling. RED FRAME
« Reply #44 on: February 10, 2012, 02:35:23 PM »
fuel tank detail
CB500K Re Styling
Offline Tews19
  • I am no
« Reply #45 on: February 10, 2012, 02:52:11 PM »
Are you missing the rubber part that connects the frame to the tank? I don't think you want metal on metal an possibly ruin your tank
« Last Edit: February 10, 2012, 03:09:43 PM by Tews19 »
1970 Honda CB750 survivor.
Offline MrGardman
  • Northern Indiana
« Reply #46 on: February 10, 2012, 03:07:26 PM »
Very nice job. Great photos also. Plus I just love those red frames. I think you have a real winner there. Can't wait to see the finished project.
Offline SohRon
« Reply #47 on: February 11, 2012, 09:14:34 AM »
This is looking good. I like your choice of colors and design on the tank and covers. Keep it up!  :D
Offline Lorbaez
  • CB Power
« Reply #48 on: February 12, 2012, 12:11:41 PM »
Thanks for the comment, I just put fuel tank over the frame, it is not fixed. Obviously I will use the rubber when the tank is fixed.
CB500K Re Styling
Offline Lorbaez
  • CB Power
« Reply #49 on: February 12, 2012, 12:14:02 PM »
Thanks Mr Gardman. I also love red frame. My biggest concern when I decided to paint it is that you can not come back to the origin unless you make all the job again.
CB500K Re Styling
