Author Topic: CB500K restoration and re-styling. RED FRAME  (Read 16508 times)
Offline Lorbaez
  • CB Power
Re: CB500K restoration and re-styling. RED FRAME
« Reply #50 on: February 12, 2012, 12:17:37 PM »
This is looking good. I like your choice of colors and design on the tank and covers. Keep it up!  :D
Thanks SohRon, I see your comments in other posts, and you are an inspiration for some of us. In fact, use the procedure to install the engine into the frame explained by you. Very simple, quick and safe for the paint.
CB500K Re Styling
[http://forums.sohc4.net/index.php?topic=101860.0]
Offline Lorbaez
  • CB Power
« Reply #51 on: February 12, 2012, 12:38:49 PM »
Thanks to SohRon (and some others), I intalled the engine into the frame in a simple, fast and safe way. I protected the frame with some bubble plastic but if you have some help it is not needed.
CB500K Re Styling
Offline Lorbaez
  • CB Power
« Reply #52 on: February 12, 2012, 01:10:33 PM »
I started riding in the 90’s, all my bikes have had disk brakes. In fact I never faced any problem with brakes, even with track motorcycles.  But I recognize that the first time I arrived to the corner with my new CB500K and I pushed front brake lever I was really afraid, nothing happened, speed was the same, fortunately rear brake works OK so I could enter into the corner. In this moment I decided that first improvement should be new and modern brakes. It’s nice to have a bike as original as possible but safety is the first for me.
Once I removed front caliper I saw the problem: Piston was seized due to oxidation. Maybe it is possible to use original brake system, let's work on it.
CB500K Re Styling
Offline Lorbaez
  • CB Power
« Reply #53 on: February 12, 2012, 01:23:31 PM »
If the original brakes do not satisfy me, then I will copy FunJimmy's front fork. I'm sure all you know the CB550 Cafe Interceptor.
But I found a simple way to do it: FunJimmy used a Yamaha front fork, this selection created some troubles to install steering bearing into the frame.  I will use a front fork from a Honda CBR600RR 03ym, the first RR has also a conventional fork, but diameter and general dimension of the steer tube are same as CB500K.
The only problem is that RR forks are 45mm diameter, probably visually to much for CB500K.
CB500K Re Styling
Offline Lorbaez
  • CB Power
« Reply #54 on: February 12, 2012, 01:33:25 PM »
CBR600RR ofset is 35mm and CB500K 45mm. This will increase trail. According my calculation new trail will be 123mm (if I use 19 inches wheel).
CB500K Re Styling
Offline Lorbaez
  • CB Power
« Reply #55 on: February 12, 2012, 01:38:56 PM »
In Spain all vehicles has to pass a periodical inspection. they check that the vehicle is according manufacturer's indication, If wheels diameter are not the same diameter as indicated into the technical card, the inspector reject them.
This is why I do not want ot use 18 inches wheel but If this trail is too much and i notice problem when cornering I will do it.
CB500K Re Styling
Offline Tews19
  • I am no
« Reply #56 on: February 12, 2012, 02:50:30 PM »
Sweet! Can we see the forks mounted?
1970 Honda CB750 survivor.
Offline Lorbaez
  • CB Power
« Reply #57 on: February 13, 2012, 02:28:52 PM »
It is not installed. It is an alternative plan just if std brake does not satisfy me
CB500K Re Styling
Offline Tews19
  • I am no
« Reply #58 on: February 13, 2012, 02:39:05 PM »
1
AHH got ya.. ANything with STD wouldn't satisfy me! I would stay clear of those STD's!
Offline wedoo2
« Reply #59 on: February 14, 2012, 05:44:06 AM »
I've enjoyed your posts and the way you are approaching the the build.  You're getting close now.  In the original post, the pipes looked very nice; are you going to keep them?
Some days the sun is too loud.
Offline Lorbaez
  • CB Power
« Reply #60 on: February 14, 2012, 12:23:18 PM »
Yes, I will use the same ones.
CB500K Re Styling
Offline Lorbaez
  • CB Power
« Reply #61 on: February 14, 2012, 12:24:55 PM »
This week I have received new sweets.
CB500K Re Styling
Offline Lorbaez
  • CB Power
« Reply #62 on: February 14, 2012, 12:35:06 PM »
I also chromed some parts. I made a mistake with some of them: I sandblasted them together with the frame, this caused a lot of troubles to chrome the parts. This is why battery stay and electics stay are not perfect.  The professional suggestion was: If you want to chrome, do not touch the parts and give them to me. I will polish and prepare them to get the better finish.
Beginners mistake from my side  :P
CB500K Re Styling
Offline Lorbaez
  • CB Power
« Reply #63 on: February 14, 2012, 01:48:46 PM »
more parts crhomed
CB500K Re Styling
Offline Lorbaez
  • CB Power
« Reply #64 on: February 14, 2012, 01:56:52 PM »
A picture of the bike with the swingarm and rear Marzocchii shocks
CB500K Re Styling
Offline Lorbaez
  • CB Power
« Reply #65 on: February 14, 2012, 02:01:37 PM »
and 2 pictures to encourage myself
CB500K Re Styling
Offline Lorbaez
  • CB Power
« Reply #66 on: February 14, 2012, 02:04:53 PM »
Here they are. The picture was done one week ago so seat cover was the old ones.
« Last Edit: February 14, 2012, 02:09:35 PM by Lorbaez »
CB500K Re Styling
Offline Tews19
  • I am no
« Reply #67 on: February 14, 2012, 02:28:52 PM »
Your bike is SICK!
Offline Lorbaez
  • CB Power
« Reply #68 on: February 15, 2012, 02:12:38 PM »
Your bike is SICK!
thanks man. Yours is also really well done.
CB500K Re Styling
Offline Mcwilliams570
« Reply #69 on: February 15, 2012, 02:26:31 PM »
Looks great so far man..Keep it up.
Matt
My CB550 project http://forums.sohc4.net/index.php?topic=101182.0
Project UFB Cb550 http://forums.sohc4.net/index.php?topic=112143.0
Like a 10 dollar hooker on Friday night its going to be ridden.
1974 cb550
1975 cb550
2005 vmax
2009 vmax-sold
1981 gl500i
Offline Lorbaez
  • CB Power
« Reply #70 on: February 16, 2012, 01:09:25 PM »
Matt
Thanks, its hepful to receive positive comments.
CB500K Re Styling
Offline Lorbaez
  • CB Power
« Reply #71 on: February 16, 2012, 01:10:58 PM »
Carburetor installation:
To be honest it has been hardest to install carburetors battery and its air cleaner chamber than engine installation
First I installed carburetors but then there was no space between them and frame to install air cleaner chamber. Then I removed carburetors and made a big package (carburetor+air cleaner chamber) it was no possible to install. Then I removed inlet manifold and made a biggest subgroup ( manifold+insulators+carburators+air cleaner chamber) but no space between cylinder head and frame to install it.
Finally I removed rubber stacks from chamber and install parts in order:
1st: manifolds, left and right
2nd: insulators and clamps
3rd: Carburetors
4th: air cleaner
5th stacks and clamps
6th air filter box
CB500K Re Styling
Offline Lorbaez
  • CB Power
« Reply #72 on: February 16, 2012, 02:44:08 PM »
I have a doubt that I’m sure some of you will solve:
Some days ago while viewing pictures of my bike I noticed something strange: Rear fender is not concentric with rear wheel. Initially I assumed that is due to rear shocks but then I saw that rear blinkers are not fixed to the frame but to the rear fender.
Then checking the rear fender I saw that it is not original, it has two weld studs in the front. AS far as I know these studs are not original but I don’t if some other Honda model have them.
Can you confirm where this fender is part from?
Thanks in advance
CB500K Re Styling
Offline Lorbaez
  • CB Power
« Reply #73 on: February 16, 2012, 02:45:32 PM »
You can see that rear indicators are not in the right place
CB500K Re Styling
Offline liPPy
  • 1978 cb750k
« Reply #74 on: February 16, 2012, 03:23:29 PM »
Loving this build thread! Very thorough, methodical and with lovely clear pictures.
Oh, and that B&W tank with the red frame looks amazing!
