Author Topic: Front End Swap question...  (Read 1080 times)
Offline Zev Fisher
« on: February 04, 2012, 08:08:20 PM »
Hey All,
I know the topic of front end swaps has been covered a ton here, but couldn't find exactly what I was looking for and still had a question...
With a front end swap, when you press the original honda stem into the new triple clamp, how do you secure the top clamp down to tighten the whole thing up if the new tree has a different thread type?
For example, I'm looking to swap out a Ducati Sport Classic front end on my 750, and ducati has a specific top nut for their triple tree (see pic below). If I end up pressing in the honda stem, this ducati nut most likely wouldn't thread to the top of the honda stem. How do people usually get around this? Is the best approach just to make up a custom stem?
Thanks!!
-Zev
Offline grcamna2
Re: Front End Swap question...
« Reply #1 on: February 04, 2012, 08:20:33 PM »
You may have to make up a custom stem...or use the Honda CB stem and make up a custom top nut using the Ducati piece some how; do you do fabrication ?
Offline Zev Fisher
« Reply #2 on: February 04, 2012, 08:40:42 PM »
Pretty basic fabrication and welding, but I don't have a lathe or a mill...luckily I know a great machinist  ;D
Also, when the new stem is pressed in, are these usually welded also? What if you're dealing with an aluminum lower tree and a steel stem and can't weld the two materials? Is a good press fit enough to hold the stem into the bottom tree safely?
Offline grcamna2
« Reply #3 on: February 04, 2012, 08:49:11 PM »
I believe a professional welder who does Tig welding should be able to weld those two dissimilar metals...but ask one to be sure.I would most certainly have it Tig welded and not just a press fit  ;). I've seen a few cheap steering stem/lower triples O.E. that looked swaged,but...I think they were just too cheap to weld them from the factory.
« Last Edit: February 05, 2012, 03:48:42 AM by grcamna2 »
Offline Zev Fisher
« Reply #4 on: February 04, 2012, 08:54:49 PM »
Thanks!
« Reply #5 on: February 04, 2012, 11:31:51 PM »
Use the Honda top nut...
Offline luap
  • LAWL
« Reply #6 on: February 05, 2012, 09:58:05 AM »
 might check into seeing if there are steering bearings that will work with the OD of the honda neck an Id of the ducati stem, If theres bearing why not just use the ducati stem? is it to long/short?
is the ducati stem weled in or pressed in
75-550 ffsc sold, 78-550 diamonte sold, 125s grasshopper sold, 76-550 puma sold, 78-550 tracker sold, 74-550 verde diablo Sold, 74-550 Noemani finished trying to sell. 72 500 hartail in the works
www.cb-town.com
"I dont need a bike covered in paint an chrome I know exactally bout how big my coc( is"
« Reply #7 on: February 05, 2012, 07:40:57 PM »
You can't weld steel to aluminum.
Offline geminimotors
« Reply #8 on: February 05, 2012, 07:43:15 PM »
If you're using the Honda stem, what prevents you from using the Honda nut, washer, etc?
