Author Topic: Clutch lever question/ aftermarket  (Read 2157 times)
Offline messeduptriple
« on: February 04, 2012, 11:58:52 PM »
So I got the shorty lever.. going on the clipons. (Im totally new to this please just note..and thanks for all the help everyone!...you guys are great!)
Ok, so I noticed there's a wire that's the only one coming into the clutch..but the newer aftermarket doesn't have this spot. What is this wire for? 2nd ...how do I get it out?
Will these aftermarket shorty levers be ok?
- thanks again!
Sent from my PC36100 using Tapatalk
Re: Clutch lever question/ aftermarket
« Reply #1 on: February 04, 2012, 11:59:26 PM »
« Reply #2 on: February 05, 2012, 12:00:25 AM »
I got them from dime city and was told they will for the Honda 550 76
« Reply #3 on: February 05, 2012, 12:43:38 AM »
« Reply #4 on: February 05, 2012, 06:05:55 AM »
Anyone be able to help??
Offline CycleRanger
  • No comment about being an
« Reply #5 on: February 05, 2012, 08:16:38 AM »
That wire is for the clutch safety switch.
It prevents the starter from engaging when the bike in gear unless the clutch lever is pulled in.
The switch can be removed by pushing it out from the back.
But as you notice the new clutch perch lacks a hole for the switch.
You can bypasss the safety switch but as the name suggests it's there as a safety device.
How are you going planning to replace the left control? (hi-low beam/horn/blinker switches?)
« Reply #6 on: February 05, 2012, 08:27:28 AM »
I wasn't sure. I thought I could just place this setup over the clipons and be fine?
I don't need hi beams and blinkers and horn aren't much needed I thought cause I just use hand signals and horn ...well ....figured its not a dire need. What u think? So can I bypass that wire and say f it? I understand its a safety thing but I will be fine. Ive been riding for 5 years now and always pull clutch in...I have 06 gsxr trackbike and needs to be done everytimeWhat u think;
« Last Edit: February 05, 2012, 08:29:26 AM by messeduptriple »
Offline CycleRanger
« Reply #7 on: February 05, 2012, 08:34:08 AM »
I don't need hi beams and blinkers and horn aren't much needed I thought cause I just use hand signals and horn ...well ....figured its not a dire need. What u think? So can I bypass that wire and say f it? I understand its a safety thing but I will be fine. Ive been riding for 5 years now and always pull clutch in...I have 06 gsxr trackbike and needs to be done every time What u think;
I don't know about the laws in your state but in most states at least a horn and hi/lo beam is required for the bike to be ridden on the street.
As far as the clutch switch, it's up to you.
« Reply #8 on: February 05, 2012, 08:41:41 AM »
If I cut that wire....and won't the cables from that left housing unit b fine? All the wires will still be there? It's just that wire that is the problem. Then I think I should be fine right? I'm not replacing that unit just putting it back.
Offline LesterPiglet
  • 1977 CB550F2
« Reply #9 on: February 05, 2012, 09:14:43 AM »
I disabled the clutch switch on mine a long, long time ago. Other bikes don't seem to need them.
« Reply #10 on: February 05, 2012, 09:19:57 AM »
U mean just cut it or how do I do it?
« Reply #11 on: February 05, 2012, 02:39:51 PM »
Ok...so if I play by the normal rules of gear and start in neutral will this work with electric start? I really don't care for e start ...I would be just fine using kick start..would this play a differnce???;
Offline CycleRanger
« Reply #12 on: February 05, 2012, 02:59:31 PM »
Yes, the electric starter will work with the bike in neutral.
« Reply #13 on: February 05, 2012, 03:11:21 PM »
So can I cut that wire or I still wasn't sure how it comes out?? I loosened that bolt and still it didn't move. How is it removable? Or should I cut it?
Offline CycleRanger
« Reply #14 on: February 05, 2012, 05:24:13 PM »
Do you have the shop manual? With a wiring diagram? You're going to need it!
If not you can get one here: http://www.honda4fun.com/materiale-documentazione-tecnica/shop-manual
The switch can be removed from the housing by pushing it out from the outside.
Grab the wires near the housing and push them back towards the switch.
It may be stuck, you might have to use a small screw driver or piece of wire to help push it out.
« Reply #15 on: February 05, 2012, 06:55:07 PM »
I have a haynes 550 manual I got yesterday. That's all.
There's a wiring diagram at the end but I have not a clue how to read that.
« Reply #16 on: February 05, 2012, 07:07:12 PM »
I guess I just remember the wire is tight inside...what switch should I be futzin with??? And should I be pulling on the wire or pushing in? In won't help I'd think cause its like solid in there, and when I pulled its solid.
Offline CycleRanger
« Reply #17 on: February 05, 2012, 07:13:51 PM »
  • 1977 CB550F2
« Reply #18 on: February 05, 2012, 07:15:15 PM »
Such a long time ago. I cut the wires as close to the bars as possible then just joined the other ends I think.
« Reply #19 on: February 06, 2012, 10:33:01 PM »
Will this clutch master cylinder work out?? I ordered it from dime city...said good for Honda 550.
I'm just wondering can I install that clutch wire we were talking about into this???
« Reply #20 on: February 06, 2012, 10:33:42 PM »
« Reply #21 on: February 06, 2012, 10:34:09 PM »
Or should I just stick with the shorty lever I had before??
« Reply #22 on: February 06, 2012, 10:40:37 PM »
you dont need a hydraulic clutch master cylinder on the older cb550 as its cable operated,,thatll suit a later model maybe.
« Reply #23 on: February 10, 2012, 08:17:17 PM »
I mistaked my buy and needed the brake master cylinder. I already returned the device. My ? Now is will any brake cylinder work on the 76 550?? If I can save few bucks I will buy a used one.
