Author Topic: 400f header pipe on a 350f  (Read 1955 times)
Offline fergie
« on: May 07, 2005, 06:05:27 PM »
I have asked if the (header portion only) would fit from a 400f to a 350f before.the answer I got was a definate YES. after talking to my local cycle shop,the guy there said he tried this swap and it is a definate NO.Now I am asking once again if it can be done.Has anyone actually done it?or do you just think you know. If its the latter please do not answer this question .Please only answer If you have done this.What if any mods needed to be done? cheers, Jeff.
The most interesting man in the world
don_m
Re: 400f header pipe on a 350f
« Reply #1 on: May 07, 2005, 07:23:24 PM »
The short answer is yes.  I don't know what the other guy's experience was but I have a 400F header pipe on my 350F.  Two of the pipes are clamped to the header to allow alignment.  It clears the oil filter, centerstand, etc. & fits as if it were original equipment.  I'm using a Supertrapp muffler so had to make a stay to attach it to the frame.  Also needed to make a small stop bracket for the center stand to keep it from flopping as it previously fitted up against the left, bottom exhaust, now gone.
Offline fergie
« Reply #2 on: May 07, 2005, 07:33:17 PM »
can you elaborate on the "two of the pipes are clamped to the header to allow for alignment"part of you answer.I don't quite understand what you are saying.What pipes? thanks ,Jeff.
Offline fergie
« Reply #3 on: May 08, 2005, 05:17:00 PM »
anyone out there got a 400 f header pipe for sale(cheap).Fergie
