Author Topic: Rightside foot brake spindle--- Fixed  (Read 1699 times)
Offline Tews19
  • I am no
« on: February 05, 2012, 09:33:47 AM »
How do you insert the right foot brake spindle without taking the swing are off? I tried all ways but can not get it in properly....... This is the last thing needed to do for my build....
« Last Edit: February 05, 2012, 11:37:25 AM by Tews19 »
1970 Honda CB750 survivor.
Re: Rightside foot brake spindle????
« Reply #1 on: February 05, 2012, 09:34:59 AM »
Did you remove the rod?
« Reply #2 on: February 05, 2012, 09:40:13 AM »
If the wheel is on, rod comes off. If no wheel, it shoudn't be a problem. The lever part does need to be between the engine and swingarm tube. Many here have settled for installing it with the lever too far back towards the rear. Brake won't adjust if so.
Offline Tews19
  • I am no
« Reply #3 on: February 05, 2012, 09:44:44 AM »
Thanks MC, tire is on. I removed the bar that connects to the rear drum already... You are correct in regard to the lever being between the swing arm and engine. Thats the part I can't get to properly. Will I have to remove the swing arm? Or is an option to remove the right side part of the swing arm bolt half way and lift the swing arm up as much and guide the lever that way?
« Last Edit: February 05, 2012, 10:13:21 AM by Tews19 »
« Reply #4 on: February 05, 2012, 09:49:46 AM »
Thanks MC, tire is on. I removed the bar that connects to the rear drum already... You are correct in regard to the lever being between the swing arm and engine. Thats the part I can't get to properly. Will I have to remove the sing arm? Or is an option to remove the rigth side part of the swing arm bolt half way and lift the dwing ar up as much and guide the lever that way?
Its been a while since I did mine. First no the swingarm does not have to come off. You have to hold your mouth just so. I'll go check mine and see if i can remember the trick.
« Reply #5 on: February 05, 2012, 10:07:09 AM »
I forget, it is a 750 K correct?
I can't see any obstacle to it other than the rod and the spring.  Your rod is off and the spring will put up a fair fight but it will lose.
Other than that it should slide right in I think.   :-\
« Reply #6 on: February 05, 2012, 10:10:59 AM »
I just had the same problem with a '76 cb550f, I couldn't find a way to do it without swing arm removal...just sayin'...hopefully, MCRider is right and the 750 is different...
Offline Tews19
  • I am no
« Reply #7 on: February 05, 2012, 10:14:45 AM »
This is on my 75 550F build. i wont be playing with the 750 until the 550 is completed.
Offline Tews19
  • I am no
« Reply #8 on: February 05, 2012, 10:16:00 AM »
Rather then removing the entire swing arm, wouldn't I be able to remove the blot that holds the swing arm. Let the front of the swing arm drop while have the rear axle installed still?
« Reply #9 on: February 05, 2012, 10:20:19 AM »
Oops, my bad. Not a 500/550 guy. You're on your own.  :(
Offline Tews19
  • I am no
« Reply #10 on: February 05, 2012, 10:25:14 AM »
HAHA wow not cool. I will figure this out
« Reply #11 on: February 05, 2012, 10:31:20 AM »
can't think of any reason that wouldn't work...I did pretty much the same, I just unbolted the shocks too and pulled out the whole wheel/swingarm shebang...debatable whether this wasn't more awkward and frustrating than just taking the wheel off properly...I'd definately try what you propose above first
Offline Tews19
  • I am no
Re: Rightside foot brake spindle--- Fixed
« Reply #12 on: February 05, 2012, 11:38:25 AM »
Update, I removed the swing arm bolt, and bumped it upwards by hand. Lever fit in and bumped the swing aarm down with my hand. All good to go... Easy smeezy
« Reply #13 on: February 05, 2012, 11:45:31 AM »
Interestin and Good Deal.
Have a SUPER day.  ;)
