Author Topic: Is there a 750 wiring loom layout anywhere?  (Read 1593 times)
Offline grumpy
  • ..... '73 750K3 .....
« on: February 08, 2012, 07:58:09 PM »
I need something that shows the layout of the actual loom and all the connections.
The regular shop wiring diagram isn't helping me much - some of my wires have been changed - the colors don't match.
I'm not getting continuity in a couple of places.
E.G. between the front brake switch and the tail light.
I need to be able to see where particular wires are connected in the loom so I can trace the odd colors back to their origins.
Offline cougar
  • Stamping Ground, Kentucky U.S.A.
Re: Is there a 750 wiring loom layout anywhere?
« Reply #1 on: February 09, 2012, 08:28:06 PM »
Hey grumpy ; I don't think this is what your looking for, but it may help. At least I hope it does.   http://oldmanhonda.com/MC/wiring750K1.html   ...cougar...
I'm not prejudice, I'll weld anything that pays! Knowledge that is shared is Never Lost!!   Right is right, wrong is wrong! The truth is the truth and a lie is a lie! DEAL WITH IT ACCORDINGLY !!!   I HATE "DIAL-UP"
bollingball
« Reply #2 on: February 09, 2012, 08:45:19 PM »
Grumpy I hate to say it but only the guy that changed the wires knows where they go now. You will have to tug and pull to find them. But I and others may help if you list each issue like you did with the front brake. What bike year and size? they are mostly close to the same. But there were some changes. Bad thing is that doesn't mean the PO followed the same path. I know the 1978 750 K model pretty good but still need the print in front of me. Tell us the bike or did I miss that?
                                 Ken
Offline the technological J
  • deliciouso!
« Reply #3 on: February 09, 2012, 09:35:54 PM »
do you have an open wall? i saw some one put theirs tacked on a wall and worked things out from there.... you can cut the wrap off and re wrap it with electrical tape
94 ST1100..Gone
72 750 K2 Stay tuned!
Offline Kevin D
  • SE Michigan
« Reply #4 on: February 10, 2012, 01:34:56 PM »
There might be some help for you here on p19-20:
http://data.sohc4.net/HSMCB750_5.pdf
This manual is for early k
My own front brake light wires were broken from 40 years of flexing with every turn of the handlebars. The wire jacket looked OK but the copper strands were broken inside the jacket, oh a few inches back from the connectors. I got some superflex wire and peeled the harness back a bit under the gas tank and spliced them in. No more problems.
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
bollingball
« Reply #5 on: February 11, 2012, 11:45:36 AM »
Grumpy About your stop light circuit. Let's say it starts at the front stop Sw. power comes in as a black wire then turns into a green/yellow wire from there it goes into the headlight bucket to a five or six pin connector comes out of the bucket goes in the main harness. Then out the harness at the rear of the fuel tank. Then it goes two places one is the rear stop Sw. and the other is on top of the rear fender under the seat. there is a bullet connector there with a few others it is still a green/yellow wire or in your case it should be :) From there it goes to one more and the last bullet at the stop light.
 Is this the information you are looking for??
Have not heard back from you. did you figure it out?
                                          Ken
bollingball
« Reply #6 on: February 11, 2012, 11:50:29 AM »
You will not get continuity from there.
                                         Ken
Offline grumpy
« Reply #7 on: February 11, 2012, 12:26:50 PM »
That's what I was looking for. That helps a lot.
I just wish that was in color
I'm really tempted to get a new loom - Or just build my own.
                                         Ken
There should be - the green/yellow wire off the brake switch joins with the G/Y wire from the rear brake switch and then goes to the tail light, right???
750K3 btw  :-[
« Last Edit: February 11, 2012, 12:31:10 PM by grumpy »
Offline grumpy
« Reply #8 on: February 11, 2012, 12:38:16 PM »
DING! DING! DING!
That's it!
I pulled the connectors off the switch & gave the green a tug and about and inch of wire pulled right out of the jacket!
SOLVED!!!
Thanks!!
bollingball
« Reply #9 on: February 11, 2012, 12:51:08 PM »
Grumpy I was joking a little. You said TAIL light not Stop light They are not the same.Tail light has a brown wire. ;D ;D
                                       Ken
Offline grumpy
« Reply #10 on: February 11, 2012, 12:54:12 PM »
oooooooooooooh  :P ;)
bollingball
« Reply #11 on: February 11, 2012, 12:59:12 PM »
There is a very good color print here that you could use along with that one you like from Kevin D. I have a copy somewhere if you want it.
                                              Ken
« Last Edit: February 11, 2012, 07:14:16 PM by bollingball »
« Reply #12 on: February 11, 2012, 01:11:55 PM »
Thanks, I saved that file and printed myself one page for shop use.
« Reply #13 on: February 11, 2012, 04:09:34 PM »
This help anyone..?
