Author Topic: help with a cam chain tensor question  (Read 1195 times)
Offline andy8190
« on: February 09, 2012, 10:48:11 PM »
How important is part number 20 in this picture. I cant seem to find them anywhere and i am waiting to install the holder. Can i just get some regular 6mm washers? If so do they need to be steel, aluminum, or copper or can i get some other kind like zinc? Thanks in advance.
Re: help with a cam chain tensor question
« Reply #1 on: February 09, 2012, 10:51:46 PM »
I THINK they are a straight steel washer
Offline ttr400
    • ttr400 Projects and Billet parts.
« Reply #2 on: February 09, 2012, 11:25:40 PM »
My parts book shows 2 x M6x16 flanged bolts, which is what I use. less chance of washers falling in to the engine.
If you don't have these then yes these will be a steel M6 flat washer.
Kevin
CB400F- 492 Yoshi Racer.
Cb400F- 466 Yoshi Cafe.
CR750 D Mann Replica.
VFR750R- RC30 - 1988.
www.ttr400.com
Offline jessezm
  • '77 cb400f cafe build
  • Always wrenching...
« Reply #3 on: February 10, 2012, 07:01:48 AM »
Yeah mine are def. flange bolts in my engine as well...
Offline andy8190
« Reply #4 on: February 10, 2012, 11:58:30 AM »
My parts book just said 6mm washers and I can see where the old washers were sitting on it and its def a circle shape and not the shape of a flange washer
« Reply #5 on: February 10, 2012, 12:06:55 PM »
wHAT'S the part number? That will tell you (or someone who understands the system) whether they are standard washers or not.
« Reply #6 on: February 10, 2012, 01:10:19 PM »
94101-06000 is usually standard garden variety 6mm flat washer.
Offline andy8190
« Reply #7 on: February 10, 2012, 05:57:30 PM »
The hardware store didn't have any flat washers that were 6mm buy they had lock washers that were. Think this would hurt anything? They are little thicker
Offline ttr400
« Reply #8 on: February 11, 2012, 12:17:14 AM »
Just go and get some M6 flat washers steel or stainless. Spring or lock washers are not required here. Or get the correct M6 x 16 flanged bolts. OEM from Honda.
Kevin
www.ttr400.com
