I'll post pic when I go outside later. If you look at the bike it has two separate slots that the forks go in to hold them steady and in place. The top triple and theres a lower slot as well. What is that?? Lower brace?? I have bad knowledge of proper names. I was thinkn lower fork brace.
Sent from my PC36100 using Tapatalk
Ah, that's the lower triple, or steering stem. A brace is an add on accessory, not (usually) part of the original equipment.
So yeah, you'll need to prop the front up (weight on the seat while its on the center stand) pull the front wheel, pull the fork tubes out of the triple clamps, disassemble the triple clamps (top and lower) bearings fall out. Reassemble with the shiny chrome part.
