Author Topic: RE: First Time Gapping Rings on CB750  (Read 867 times)
Offline chewbacca5000
  • I polish covers!
« on: February 11, 2012, 07:48:06 PM »
This is my first time gaping rings on a CB750.  My bore is the 2nd oversize 63.5mm / 2.5".  From reading other post I know I am to multiply.004 X 2.5 which gives me .1 end gap on my top ring and that is exactly what I have.
Is this correct?  What is an ideal end gap.
Thanks!
Re: RE: First Time Gapping Rings on CB750
« Reply #1 on: February 12, 2012, 04:20:46 AM »
You probably meant 0.010." (10 thou) That's a good number but I really don't like anything less than that. Check them all and make sure the ring is square in the bore when you check.
  • I polish covers!
« Reply #2 on: February 12, 2012, 04:54:39 AM »
Ring is square in the bore used to piston to push the ring down an inch or so.  Using the feelers I got .011" for the second ring and .010" for the first ring.  So I should be all set no need to gap either of these rings.
