Author Topic: Case bolts? 6mm Flange style...  (Read 1679 times)
Offline stueveone
« on: February 11, 2012, 07:54:45 PM »
What are you guys doing for 6mm case bolts? Any sources out there for the whacky metric flange lengths? Stainless?
Thanks!
« Last Edit: February 12, 2012, 05:37:45 PM by stueveone »
Offline brandEn
Re: Case bolts? 6mm lange style...
« Reply #1 on: February 11, 2012, 08:29:31 PM »
Check it
http://www.inoxbolt.co.uk/zen/
They are in the UK though.
« Last Edit: February 11, 2012, 08:40:02 PM by brandEn »
Offline tomkimberly
« Reply #2 on: February 11, 2012, 08:47:50 PM »
Have you tried your local ACE Hardware store?
Tom
Offline Steve_K
« Reply #3 on: February 12, 2012, 06:34:27 AM »
Some of the case bolts are different lengths.  Ace  has 20 or 25 mm long bolts.  Some case bolts are say 22 long.   Shorten the 25mm to fit.   The 3 extra mms may bottom and cause damage.  Put a nut on the screw before grinding and put a chamfer on it and remove the nut.  Its ready to go.
Steve
Steve_K
Offline Ernest T
« Reply #4 on: February 12, 2012, 09:36:31 AM »
Use OEM Honda bolts for a 1983 CB1100F, they are chrome hex head bolts and they come in a variety of odd lengths such as 16, 18 and 32mm.
Here they are on my XL 350 instead of the philips head screws.  I just ordered them for my CB400F rebuild.
The part number is 96001-06014-00  for a 14 mm bolt.  Replace the 014 with the length you want then put it in the Honda parts finder at your favorite on-line seller to make sure its a good length.  I haven't come across many sizes that aren't available.
« Reply #5 on: February 12, 2012, 10:09:43 AM »
 CUT ith nut on, chamfer, then WIRE WHEEL the bolt, just cause it dont bruise a steel nut does not guarantee it wont shave some aluminum off.
 Those flanged chrome heax heads look really good..
Offline stueveone
Re: Case bolts? 6mm Flange style...
« Reply #6 on: February 12, 2012, 05:43:59 PM »
Thanks for your input guys. Yep, no slouch to customizing bolt lengths. The difficulty I am having is finding an M6 flange bolt that is 100mm long ie case bolts. So. . . I think I'm going to go with stainless socket bolts with washers.
Here's where I'm getting them. Price seems reasonable. . .
http://www.boltdepot.com/Metric_socket_cap_Stainless_steel_18-8_6mm_x_1.0mm.aspx
Offline Ernest T
« Reply #7 on: February 12, 2012, 06:49:11 PM »
Honda has them.
QUANTITY PART RETAIL  YOUR PRICE
       BOLT, FLANGE (6X100) (96001-06100-00 )  $1.44 $1.08
Offline Pecantree
« Reply #8 on: February 12, 2012, 09:59:53 PM »
Here's a vendor I like. And they have 100 and 120 mm Stainless bolts.
http://dmpfasteners.com/shop/nuts-bolts-washers-1824/bolts-76/hex-metric-stainless-83/m6-1332/
Ordered some button head stainless for the covers.
They have a pretty fast turnaround, usually about 4 days to get from CA. to Austin.
Good luck
Steve
