Author Topic: Installing Mac exhaust  (Read 1995 times)
« on: February 12, 2012, 05:06:28 AM »
I have new old mac 4 to 1 exhaust. Comparing original spigots to this exhaust the distance from the flange to the sealing end the mac is inch longer - too long for the head actually.
I am thinking about cutting that end shorter to get the flange - after crushing the copper washer - to sit directly on the head.
Is there a trick to mac exhausts or anybody has experience with it?
Thanks!
Offline dhall57
Re: Installing Mac exhaust
« Reply #1 on: February 12, 2012, 05:36:03 AM »
This is the Mac 4 to 1 system that the PO had put on my K6. Maybe this pic will help 70CB.
1970 CB750KO
1971 CB500KO-project bike
1973 CB350G- project bike
1974 CB750K4-project bike
1974 CB750K4
1976 CB750K6
1977 GL1000
1997 Harley Wideglide
« Reply #2 on: February 12, 2012, 06:02:57 AM »
Thank you, is there space between the flange and the head?
Offline Steve_K
« Reply #3 on: February 12, 2012, 06:18:34 AM »
I have a similar exhaust and it used the allen head cap screws to hold it to the head.  Mine is hanging on the shop wall and I want to use studs to hold it on.   Anyone know how long they should be using washers, lock washer and the nut?
Steve
Steve_K
Offline dhall57
« Reply #4 on: February 12, 2012, 07:08:37 AM »
I've had the pipes off several times for painting, etc. and mine have no spacers, just the mounting plates that are part of the pipe assembly.  The pipes just bolt down to the exhaust head studs.
1970 CB750KO
1974 CB750K4
1976 CB750K6
1977 GL1000
« Reply #5 on: February 12, 2012, 09:35:53 AM »
Thanks!
did you get this pipe used?...did it come with the allen head bolts?...cuz any others might not be long enough...just to be clear, the original spigots will be removed and not used.  I would worry that cutting those flanges shorter would cause the pipe to not clear/line up somewhere else...was hoping this pic was more of a detailed close up, but it hopefully might help
« Reply #6 on: February 12, 2012, 12:08:39 PM »
The problem i see is that with the pipes in place there is almost an inch between the flange and the head. On every exhaust flange i ever saw the flange bolted down to the head with no space between.
It is like i cant get the pipe in the head deep enough.  Will post pictures.
Offline Dimitri13
  • 1974 CB550K
« Reply #7 on: February 12, 2012, 12:20:38 PM »
Make sure you've removed the old exhaust gaskets. They can blend it.
Offline Really?
« Reply #8 on: February 12, 2012, 12:23:26 PM »
If you bought it used and it did not come with the rest for the centerstand, they have them at cb750supply.com
The Wife's Bike - 750K5
The Kid's Bike - 750K3
Offline dhall57
« Reply #9 on: February 12, 2012, 12:31:08 PM »
Here's a pic of the mac pipe mounted on #1 cyl.
1970 CB750KO
1974 CB750K4
1976 CB750K6
1977 GL1000
« Reply #10 on: February 12, 2012, 01:42:24 PM »
Thank you, sir. Thats exactly what have me confused. I was expecting the flange to sit on the head port.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #11 on: February 12, 2012, 06:29:18 PM »
The flange is not designed to fit flush, it merely provides the clamping force. Studs with nuts are recommended, that way the force on the aluminum threads in the head are merely a pulling force, since bolts exert pulling AND twisting/shearing forces as they are torqued.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
« Reply #12 on: February 13, 2012, 03:40:53 AM »
Got it, thank you!
