Author Topic: gas tank lock cylinder gone from CB 550F tank  (Read 1078 times)
Offline apehanger 550
« on: February 13, 2012, 05:27:24 AM »
  The lock cylinder from my CB550 gas tank cover arm worked just once when I put the key in,and then it came completely out. It is just a cheap piece of white plastic.  Not even sure if it is OEM
  Any suggestions on how to proceed and parts sourcing would be appreciated.
Offline mcpuffett
Re: gas tank lock cylinder gone from CB 550F tank
« Reply #1 on: February 13, 2012, 07:22:51 AM »
Hi can you post apicture of what you have may help us identify what you have and how to proceed  ;), cheers Mick.
Online bryanj
« Reply #2 on: February 13, 2012, 09:25:08 AM »
Is this the sort with a "Flap" over the tank cap? If so it sounds like the inner lock part has come out of the plastic surround if so you need Honda part number 37220-390-003 which is held in by a clip 37221-390-000
« Reply #3 on: February 16, 2012, 09:34:52 PM »
  That's it Brian. The flap has the key cylinder in it. thank you so much for posting the part numbers..
