Author Topic: any issues to removing fork boots?  (Read 3216 times)
Offline ianfotheringham
« on: February 13, 2012, 06:10:41 AM »
On a cb750 - if one wanted to remove the black rubber accordioned fork boots, what needs to be done to ensure they don't get overly filled up with dirt/dust?
thanks guys
Re: any issues to removing fork boots?
« Reply #1 on: February 13, 2012, 06:18:00 AM »
Ian, you need to ask yourself, why were they put on in the first place.
Sam. ;)
Offline Johnie
« Reply #2 on: February 13, 2012, 06:28:07 AM »
Once you get them off you will probably find some bad looking metal tubes which are covered nicely by the gators. But if you are set to take them off you can get some rubber funnel looking covers that are on the later Honda's that would work to keep the dirt out of the fork seal area. Take a close look at my 81 CM400C and note the fork seal covers. Click the pic to enlarge it.
« Last Edit: February 13, 2012, 06:31:16 AM by Johnie »
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline lone*X
« Reply #3 on: February 13, 2012, 06:29:45 AM »
I agree, I prefer the gators as they do a great job protecting the swept area of the tube from dirt and dinks.  Even Honda though sometimes went for the looks over function.  These are probably what you are looking for.
http://www.ebay.com/itm/Honda-CB750-Fork-Dust-Seal-Set-500-550-750-CB500T-CB550F-CB550K-CB750A-CB750F-/320842458100?pt=Motorcycles_Parts_Accessories&vxp=mtr&hash=item4ab3b363f4
Lone*X  ( Don )
75 CB550K1
VTX1800C for two up cruisin.
nomad
« Reply #4 on: February 13, 2012, 06:35:58 AM »
Or if your intent is to simply get rid of the stock ears, but you like the look of the accordion fork boots, you could get these... http://www.jokermachine.com/itemcafe2004.asp?ItemID=694&CategoryID=85&Placeholder=.  This would allow you to use aftermarket ears and keep your accordions.
« Reply #5 on: February 13, 2012, 06:37:26 AM »
these are all true and good points - but as my current tubes are fairly rusted...i've decided to go with cycle-x's lowering kit...may as well show off the new and shiny tubes....right?
Offline Really?
« Reply #6 on: February 13, 2012, 07:21:04 AM »
I did.  CycleX -2's with their dust caps.  And I slid the tubes up another 1 1/4"  You can get an idea of what you might get with the stance.  I did not like the 18" rim in the back with the shorty shocks so I laced a 16'rim.  To me it looked horrible and too far up in the fender.
The Wife's Bike - 750K5
The Kid's Bike - 750K3
bollingball
« Reply #7 on: February 13, 2012, 07:46:17 AM »
thanks guys
What needs to be done? well how about putting them back on ???
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #8 on: February 13, 2012, 02:59:17 PM »
I put early 750 forks on my late 550 and wanted to use caps instead of gators.  My 550 caps wouldn't fit, but I did find a solution.  Here's what I did (including part numbers).
http://forums.sohc4.net/index.php?topic=66583.msg732842#msg732842
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
