Author Topic: Frame fun  (Read 1121 times)
Offline TonUp550
Frame fun
« on: February 14, 2012, 05:41:42 AM »
I have a 74 CB and was thinking about cropping the back half of the frame and gonna build it to a spec i like. I know a little bit about welding but before i cut was gonna see what you guys recommend for tubing to build it. IE size and thickness. I am on a tight budget.
Offline wedoo2
Re: Frame fun
« Reply #1 on: February 14, 2012, 05:58:05 AM »
Welcome.  Member 754 says that:        CB 750 is 1 inch OD    .060 wall..
There is a search system here that works pretty good sometimes.  Lots of tips and tons of help.  There are several people that have done just what you are wanting to do and are willing to help.  Manuals as well.  Put down the motor size and that will help.
Some days the sun is too loud.
Offline TonUp550
Re: Frame fun
« Reply #2 on: February 14, 2012, 06:54:43 AM »
Sorry the bike is a 1974 CB550
Offline Really?
Re: Frame fun
« Reply #3 on: February 14, 2012, 07:12:49 AM »
When you search, you will get better results if you are on the Home Page.  Good luck with the Search-Fu, I still have trouble.  Might be my keyword choices, I dunno.
The Wife's Bike - 750K5
The Kid's Bike - 750K3
Offline lucky
Re: Frame fun
« Reply #4 on: February 14, 2012, 10:56:05 AM »
So where did you go?
What happened?
By the way I would use tubing thicker than.060 (1/16) because it can get backed into a wall etc., and you do not want the tubing to get dented.
« Last Edit: February 14, 2012, 04:17:55 PM by lucky »
