Author Topic: 1977 CB550K - Pull Cable?  (Read 541 times)
Offline flateric
« on: February 14, 2012, 10:28:59 AM »
I am currrently restoring a 1977 CB550K.
I bought brand new cables for the bike but the Pull cable I got seems to be too short (not the cable itself but the cable inside the cable; hope this makes sense). The "inside cable" is not long enough to go around the metal "disk" at the carb...
Did I get the wrong cable? Is there a difference in cable size between a 1977 CB550K and other 1977 CB550? What cable should I get?
Thanks for your help.
Re: 1977 CB550K - Pull Cable?
« Reply #1 on: February 14, 2012, 11:18:28 AM »
Yes. You need one for a 77 or 78 K model only.  The F models and all prior years use a different style carb as the PD used on the 77 and 78 K models.
« Last Edit: February 14, 2012, 01:17:39 PM by TwoTired »
Offline flateric
« Reply #2 on: February 14, 2012, 11:25:58 AM »
Great... I will order one today then... Thank you
Offline flateric
« Reply #3 on: February 15, 2012, 09:06:04 AM »
Looks like I got a cb550f cables. I ordered a new pull cable because the F version is too short.
The push cable seems to work but am i wrong thinking that a F model push cable would fit a K model?
« Reply #4 on: February 15, 2012, 11:52:15 AM »
Yes.
I thought I explained that.  77K models used PD carbs.  77F models used an earlier style carb.  They use different cables.
