If you're thinking stripes, here's the way I went... silver tank, off white HONDA badge, black/ off white (same shade as badge) stripes. I'm still not sure about the chrome trim around the tank. I'm not even sure where I'd find the stuff. I may just reupholster the seat without the chrome.
Maybe these will give you an idea wether or not you want to go in this direction (with your colors of course)...
That is pretty much what I was thinking about. I would like my center stripe a little bit wider though. I have read here that you can use the plastichrome trim found at auto parts stores.
I like your gauge piece as well.
I think I figured out the headlight today. Not sure what was causing it, but I started from the beginning (jumpering the on/off switch wires) then put the rocker switch back in and everything worked. I must have goobered something up.
I thoroughly cleaned and inspected (making sure there were no cracks in the nut or flange) the oil supply line then re-attached it to the tank then attached the tank to the bike. Doing it that way I was able to torque it down bit more. Put everything else together kicked it over a number of times. Probably around the 10th or 15th kick I noticed the gauge needle starting to jump pretty good. At that point I stopped kicking and went to the electric start. Using that it held pretty solid right at 70psi. The other day when I did it, it was bouncing between 65-70 psi. I will let it sit again for a few days and see what happens. Hopefully re-torquing it down fixes the problem.
