Well work and life has been in the way for the last week or so. I fired her up again yesterday so I could check the timing and sync the carbs. I was only able to get one of them done. At first start up the #1 carb overflow tube was pissing fuel out of it. When I got the carbs back from being rebuilt that float needle had slipped down a bit on the float tang. I manipulated the tang to where it would hold the needle up and maintain the correct height, but I guess that once the bowl was drained it slipped back down. So I will tackle that issue today. For the meantime I tapped on the carb body which was enough to get the needle to sit where it was supposed to.
I let the bike warm up for about 10 minutes, shut it down, and hooked up the timing light. Fired it up with the idle sitting at 900-1000 rpm's it was spot on. I didn't have to adjust the plate at all. I some how managed to put it right on the sweet spot when I initially installed the Pamco unit. Increased the revs to 2500 to check the advancer and it was spot on as well.
The only issue I noticed was at the end of the run (about 10 minutes in) the idle started to creep up and it sort of sounded like it was hunting a little bit. Once it got to almost 2000 rpm I shut it down. I am no carb expert, but from what I gather that indicates a lean issue correct? I also noticed that the exhaust pipes started to turn a golden color. I have not messed with any settings on the carbs since I put them on. They were rebuilt (by a reputable member here) and the jets were changed to 110's. From what reading I have done I should be able to correct this by adjusting the air mixture screws?
