Author Topic: Tachometer cable oil seal.. picture?  (Read 1649 times)
Offline Dimitri13
  • 1974 CB550K
« on: February 15, 2012, 07:12:17 PM »
I searched and found many threads about putting them in and getting them out, and to use a dohc one instead of a sohc one, but I cannot find a real picture of it.
The reason I ask is because I have an engine gasket set, and I'm sure I have the seal, but I'd like to know what it looks like, so I can pick it out of the plethora of gaskets I have. Or even the dimensions would be great. Just something to identify it. I don't want to take my seal out and find that I don't have it, because my bike is my DD.
Thanks in advance :)
Offline eldar
Re: Tachometer cable oil seal.. picture?
« Reply #1 on: February 15, 2012, 08:32:11 PM »
I have never heard of using a dohc tach seal. I replaced mine with a standard seal and it does not leak a single bit.
Pull out your tach cable and look in the hole. If it is silver like the engine, you have no seal. If it is black, you have a seal, unless you have a black engine. ;)
Just fyi, if you did not have a seal, you would have a good stream of oil going down the front of your motor.
http://www.bikebandit.com/houseofmotorcycles/1978-honda-cb750k/o/m9458#sch400490
#12 is the seal.
Offline Dimitri13
  • 1974 CB550K
« Reply #2 on: February 15, 2012, 08:51:15 PM »
Well, I checked BB earlier..
#30 is a 7mm thrust washer (wtf is that?)
#40 is .. Oh. an 11x2.5 gasket. I guess they do have the dimensions there.
#35 is "oil seal." Ah, that's what I couldn't find the dimensions for. But I guess it should be pretty similar in size to #40.
Offline Dimitri13
  • 1974 CB550K
« Reply #3 on: February 15, 2012, 11:20:16 PM »
Offline cookindaddy
  • I sure love this bike!
« Reply #4 on: February 16, 2012, 02:44:56 AM »
Yes, it looks like that on one side. On the other, there is a groove. I think the groove side goes towards the oil. The top in your picture goes toward the outside.
George with a black 78 CB750K (in Lion's Head, Ontario, Canada)
