Author Topic: Is a cb750 rear hub the same as a cb550?  (Read 1290 times)
Offline dergs713
« on: February 16, 2012, 10:19:53 AM »
Quick question.  Is a honda cb750 rear hub similar to a cb550/500?  I found a couple 750 hubs laced with a harley 16'' rim.  Im looking at putting it on my cb500 project.  Should I pick up the thing?
Matt
Offline Steve_K
Re: Is a cb750 rear hub the same as a cb550?
« Reply #1 on: February 16, 2012, 05:22:40 PM »
CB550 hub has 2 bearings, the CB750 hub has 3 bearings.  I don't know if they swap or not, but I believe, no they will not.
Steve
PS never say die, but someone has likely tried and will post
Steve_K
« Reply #2 on: February 16, 2012, 11:53:46 PM »
Anything can be MADE to fit anywhere but direct swop NO
« Reply #3 on: February 17, 2012, 01:36:18 AM »
even the 500 and 550 rear hub changed,either will fit either bike but must be used with the correct brake backing plate,they wont inter swap,they share the same shoes though.
