Author Topic: CB550 Shifter seal, block off oil feed?  (Read 5655 times)
Offline Elniniomuchachos
Re: CB550 Shifter seal, block off oil feed?
« Reply #25 on: February 17, 2012, 10:42:14 PM »
I think I fixed it. I just took about a 50 mile ride and haven't seen any new drips. I put a paper plate under that area to see if any new drips arrive in the morning.
When is the relay? I'd totally be down to ride with everyone through Phoenix.
« Reply #26 on: February 18, 2012, 12:14:15 AM »
you only have paper plates because you hate washing up the dishes!
« Reply #27 on: February 18, 2012, 12:49:53 AM »
Actually paper plates make good targets...
« Reply #28 on: February 18, 2012, 02:26:46 AM »
remind me not to eat at your place then elniniomuchachosionmachaiousmousness,man you got a long tag name.
« Reply #29 on: February 18, 2012, 02:12:05 PM »
I went out to check out how the bike was holding up this morning. Only one tiny drop of oil. Which is much better than a 2-3 foot wide puddle. Hopefully it will hold for a while.
I also fixed my gas leak I had with the number four carb. last night.  I took the bowl off and noticed there was a crack in the float. I bet this happened when I wrecked last week. So I tossed that float out and took one from a spare set of carbs and now it's good to go. Though I still would like to tap the carb threads to freshen them up and get allen bolts on them. The number four carb only has 2 of the 3 bolts on right now, because one is stripped.
Offline Mooshie
« Reply #30 on: February 18, 2012, 02:59:06 PM »
I got the oil pump back on with the "newer" o rings. two of the leaks are gone, but there's one left. It looks like it's coming from the plate with the three bolts in it. Is there an o ring behind there?
BryanJ sells the "o" ring you need for that cover.  I just got one from him...I am still chasing my leak.  It stopped for about 20 days now is back, tiny little drip (well 2 actually).  Guess I will be replacing "o" rings for the next 30 days until the rally...
1976 CB550F
Standard disclaimer: Remember I am just a girl--so be nice fellows!
« Reply #31 on: February 18, 2012, 04:33:12 PM »
Yeah, I put a little bit of gasket maker around the o rings just to help a little.
« Reply #32 on: February 18, 2012, 06:03:17 PM »
So far, you are the only Phoenix rider to sign up. ???
Here is a link to our team thread:
http://forums.sohc4.net/index.php?topic=101775.0
« Reply #33 on: February 19, 2012, 01:44:28 AM »
Hmm. There's got to be more SOHC's in Phoenix...
Offline domer
« Reply #34 on: February 19, 2012, 09:13:44 AM »
Pm me if you need the oil pump cover oring. I still have a few vitons left.
