Author Topic: I should drain the oil before doing the clutch, right?  (Read 1596 times)
Offline dakeddie
« on: May 29, 2006, 10:04:55 AM »
My manual doesn't mention anything about draining the case of oil before removing the clutch.  I should though, to avoid a big mess, right?  But if I don't have to, I'd rather not, I just changed the oil.
Offline Tim.
  • www.DOTHETON.com
    • DO THE TON
Re: I should drain the oil before doing the clutch, right?
« Reply #1 on: May 29, 2006, 10:40:07 AM »
Well, I'd think so, based on my 550 manual (what manual are you reading?)
Roule comme dans les annĂ©es 70...   Roll as in the Seventies...
Offline dakeddie
« Reply #2 on: May 29, 2006, 10:45:35 AM »
Clymer.
« Reply #3 on: May 29, 2006, 10:58:46 AM »
The cb750 has a dry sump system.  In theory, oil isn't carried in the sump like on a cb550.  However, there is an anti siphon valve in the line going to the oil tank.  If that leaks, the 750 sump will fill up, too, and so will the clutch housing.
With either bike, liquids collect in the low part of a vessel.  Leaning the bike over on its side will place the clutch housing  at the high point of the vessel.
Padding, bracing, and stability of the bike are your responsibility.  As well as preventing bits of gasket, screws, and such from dropping inside the sump.
Offline Jonesy
  • Shop Rat
« Reply #4 on: May 29, 2006, 11:33:20 AM »
The sump on the 750 is far below the clutch assembly and I was able to redo my clutch without draining it. One tip is to have it on the kick stand as the oil will be away from the clutch area, as TwoTired mentioned. Have a small pan in place just in case a little dribbles out.
Here's what you'll see in there:
« Last Edit: May 29, 2006, 11:42:06 AM by Jonesy »
Offline grumburg
  • 74550, 76400F, 72 750 67S90, 68CL90, 65 s65 66 x6
« Reply #5 on: May 29, 2006, 05:50:00 PM »
Although manual does not say so, best to drain crankcase.
Fonda Honda
Offline grumburg
« Reply #6 on: May 29, 2006, 05:55:14 PM »
I am referring to 500/550.
Fonda Honda
