Author Topic: worn fork sliders  (Read 1594 times)
mblab
worn fork sliders
« on: May 29, 2006, 10:20:45 AM »
Hi all. New to this forum. Have 74 750 forks on a custom scoot and the left slider is worn such that when the brake is applied, the slider has a noticeable slop. (front and back)  Question is, as there are no replaceable bushings in the slider(at least that I've found), is there any fix other than replacement? Replacement would be a no brainer except for the fact that I've had the fender mounting lugs removed , holes welded up and I've polished the whole mess. Thanks, Mike
ElCheapo
Re: worn fork sliders
« Reply #1 on: May 29, 2006, 06:05:44 PM »
Pics of the offender please.  ;)
mblab
« Reply #2 on: May 29, 2006, 06:38:26 PM »
The offender is currently assembled and even if apart, prolly wouldn't show the wear that's causing the slop. Or did you mean the motorsickle itself?
ElCheapo
« Reply #3 on: May 29, 2006, 07:31:38 PM »
I just need to see which way the slop is and where.
Offline chung
  • Giddy Up
    • chungfucycles.com
« Reply #4 on: May 29, 2006, 11:18:35 PM »
I don't think there are servicable parts to fix that Prob, may have to replace the lowers/sliders or even the entire fork set if the chrome is gone too? (likely)
The later CB450 (1972-74ish) forks did have replaceble bushes in them and they will fit into the 750 trees although the brakes are smaller.
Member#2815
1971/76 CB750 Hack @970cc,
1975 CG750K
1970 CB350,
1972 YDS7, 250
1972 YR5, 350
1977 RD400,
1978 Piaggio Grande/Batavas HS50 Special
1981 XS650 Special II
mblab
« Reply #5 on: May 30, 2006, 03:33:48 AM »
ElCheap- The slop is fore and aft. I guess what I hoped was to (1) find if this is common (2)find out if there is a service that might be familiar with the machining necessary for a repair.
Chung-  Do you think that a 450 bushing could be fitted to a 750 fork leg with proper machining? Do you know thi part #?   Thanks for all the responses, Mike
P.S. ElCheap--The wear seems to be confined to the top of the sliders.
« Last Edit: May 30, 2006, 03:39:09 AM by mblab »
ElCheapo
« Reply #6 on: May 30, 2006, 06:51:47 AM »
Ok if the wear is in lower sections you can craft a brass collar. This is not easy but it can be done.
My guess is (even with me being the ultimate cheap skate) the time needed to invest in making a collar to stop your slop will be more trouble than just getting the replacement side and re-perform the mods you did originally to the part you have now.
Sometimes it is better just to start over..
Offline dusterdude
« Reply #7 on: May 30, 2006, 10:17:02 AM »
i would think you could by brass bushings that fit other kinds of bikes and have them made to fit you slider.
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
