Author Topic: Mystery Lines. New Owner  (Read 1786 times)
Offline Maine Ride
    • Dirigo Digital Media
« on: February 19, 2012, 01:11:14 PM »
Performing an oil change yesterday I located these lines on the right underside of the bike. 2 are blocked up with screws. What do these lines do and why would they be stopped up?
Thanks!
John
78' CB50A
Offline Maine Ride
Re: Mystery Lines. New Owner
« Reply #1 on: February 19, 2012, 01:13:12 PM »
Better pic
78' CB50A
Offline raymond10078
  • Moderator
  • Just learnin' as I go . . . .
« Reply #2 on: February 19, 2012, 02:05:11 PM »
Of the seven lines/hoses, only one should be blocked - the one from the crankcase breather/oil separator.
The seven lines are:
  • four from the carbs
  • battery vent
  • crankcase breather/oil separator
  • fuel tank overflow
From what I've seen, some crankcase breather/oil separator hoses have a special end that is "molded shut", and squeezed to open.
1978 CB750A (upgrading very, very slowly)
Past bikes - Honda: SL350, CX650C, CB900C, CB1000C, CM450A; Kawasaki: several 1972 750 H2's; Suzuki: TC90J.
Bikes I want: CX650ED, a mid-sized japanese V-twin with ABS.
Offline jonnycakes
« Reply #3 on: February 20, 2012, 03:26:08 AM »
Bet they are carb overflows........blocked up to keep the gas from coming out due to worn or miss adjusted carbs
'Matic-Fanatic
Offline Maine Ride
« Reply #4 on: February 20, 2012, 04:42:04 AM »
Hmmmm. Well when the temperature reaches above the 40 degree mark again this will warrant a further look. Either way learning the art of carb tuning is a necessary reality. Though the bike is running well, its inevitable I'm sure.
78' CB50A
