Author Topic: help with tapered bearing install  (Read 840 times)
Offline andy8190
« on: February 19, 2012, 06:12:51 PM »
I am installing tapered bearings on my cb350f and was wondering what spacer to use the thick or the thin, i searched and i think i found that you should use the thick but i do want to double check. I do not have the old bearings to reference the height
Offline andy8190
Re: help with tapered bearing install
« Reply #1 on: February 19, 2012, 06:42:45 PM »
never mind guys i used the thick washer and its good to go
Offline RickB
    • Pop Magazine
« Reply #2 on: February 19, 2012, 07:27:26 PM »
Andy,
It sounds like you figured it out but if you want to double check, I documented the installation of tapered bearings on my CB400F. The 350 and the 400 are very similar bikes as you may know so perhaps my experience can help you.
http://forums.sohc4.net/index.php?topic=51957.msg702096#msg702096
Rick.
