Author Topic: Running on three... stumped  (Read 5477 times)
Offline twincityrider
  • "It's not ink... it's grease"
Re: Running on three... stumped
« Reply #25 on: March 11, 2012, 04:40:15 PM »
Oh and one more thing.  I made the double mistake of putting Keyster parts in the carbs and tossing the old hardware.  I ended buying OEM float valves because the spring differences between the OEM and Keyster were way different.  My carbs had difficulty shutting off with the more rigid Keyster valves.  Now all appears well but I'm not convinced the Keyster stuff is speck.
"Don't touch that please, your primitive intellect wouldn't understand things with alloys and compositions and things with... molecular structures."
Offline mycb750k6
  • "res ipsa loquitur"
  • Rocketman
    • photobucket albums
« Reply #26 on: March 11, 2012, 04:57:51 PM »
Take the bowls off one at a time, check fuel level and then push up on the float to be sure fuel is flowing freely through the float valve. If so, at least you can move on and focus on something else.
The current state is it doesn't start at all now????
« Reply #27 on: March 11, 2012, 05:03:25 PM »
Will do.  Yeah, it doesn't run at all.  I'll update tomorrow.
Offline MasterChief750
  • Detonation
« Reply #28 on: March 11, 2012, 08:32:29 PM »
im not very familiar with these carbs but have you cleaned/replaced the slow jets?
1976 CB750 K - Drag Bike
I AM THE STIG
Sam is THE STIG
he said i can be STIG3 tho
« Reply #29 on: March 12, 2012, 09:13:10 AM »
Yeah I have.  Confident every conceivable passage is clear.
