Author Topic: Odd tools you can't live without  (Read 8342 times)
Offline adr3naline
  • adr3naline
    • adr3naline
« on: February 20, 2012, 08:27:07 PM »
So, I'm wondering about all you that restore and modify your bikes.  Besides the common hand tools, what not so typical tools are a necessary part of your tool box?
Today I realized I'd like to get a set of bolt thread size testers, which would make it handy to determine bolt/nut sizes. I also need to get a couple electrical testers.
2006 Yamaha Warrior
1982 CB900c
1979 CB650
Re: Odd tools you can't live without
« Reply #1 on: February 20, 2012, 08:29:48 PM »
Heat gun
« Reply #2 on: February 20, 2012, 08:37:50 PM »
Metric scale and beer bottle opener! (for the import non-twist offs)
« Reply #3 on: February 20, 2012, 08:44:37 PM »
 For the OP, get a caliper ...
other stuff... tire-irons, good 1 pull tiedowns (not ratchet type), 6 point sockets. JIS or Craftsmen screwdrivers...to list a few...
Offline lone*X
« Reply #4 on: February 20, 2012, 08:54:36 PM »
Have to have a hammer driven impact screwdriver for frozen JIS headed case screws.
Lone*X  ( Don )
75 CB550K1
VTX1800C for two up cruisin.
Offline adr3naline
  • adr3naline
    • adr3naline
« Reply #5 on: February 20, 2012, 09:09:00 PM »
Yes... I need one of those. I used a friends the other day and it was a beautiful thing.
2006 Yamaha Warrior
1982 CB900c
1979 CB650
Offline geminimotors
« Reply #6 on: February 20, 2012, 09:22:12 PM »
Two oddballs I rely on when things get odd: 1. Bees wax. With heat, it's the best penetrant I have ever used. Ever. 2. a street sweeper bristle. A 1/8" wide 6" long piece of flat spring steel. It's the perfect pokey, scrapey, fiddly thing for the weird times when you wished you had something like that.
« Reply #7 on: February 20, 2012, 10:24:17 PM »
left hand screw driver.
« Reply #8 on: February 20, 2012, 10:35:43 PM »
...and wrenches to match...
« Reply #9 on: February 20, 2012, 11:19:11 PM »
 A bit off topic, but when machining... a warding file... very handy...
Offline RickB
    • Pop Magazine
« Reply #10 on: February 21, 2012, 12:24:33 AM »
Hi all,
An odd tool that I built is for adjusting the tappets on my CB400F. Using a pair of pliers proved way too cumbersome.
After some research here on the forum, HondanutRider mentioned his son 'invented' a tool for the job. He suggested using a 'Robinson' screw as a tool. A quick call to a tradey mate with 'what the hell do we call a Robinson screw here in Australia?!' lead me to the square drive decking screw isle.
The guy at the hardware store gave me one for free and with a masonry plug as a handle, the job of adjusting the valves clearances got so much easier!
Rick.
« Last Edit: February 21, 2012, 12:26:18 AM by RickB »
Offline messeduptriple
Re: Re: Odd tools you can't live without
« Reply #11 on: February 21, 2012, 12:29:58 AM »
yep mine was a life saver few times!
Sent from my PC36100 using Tapatalk
Offline camelman
  • Man... Myth... Legend
« Reply #12 on: February 21, 2012, 12:34:20 AM »
I like that valve adjuster.
My favorite tool is a 10" hemostat.  It gets where fingers can't reach, has a sure grip, can fasten and hold items in place...
1972 350f rider: sold
1972 350f/466f cafe: for sale
1977 CB400f cafe:sold
1975 CB400f rider: sold
Offline Dimitri13
  • 1974 CB550K
« Reply #13 on: February 21, 2012, 12:34:58 AM »
For those late nights in the garage. Or even just a fiddly recessed area.
« Reply #14 on: February 21, 2012, 01:10:09 AM »
is that a jock strap with a light on it?kinky!!
Offline Dimitri13
  • 1974 CB550K
« Reply #15 on: February 21, 2012, 01:18:26 AM »
Oh jeeze, I just read your comment, then read what I wrote. Gotta get my mind outta the gutter.
« Reply #16 on: February 21, 2012, 01:53:34 AM »
a bit like that song"you need a coal miner to find her vag---a."
Offline MoMo
  • Ride like you're invisible
« Reply #17 on: February 21, 2012, 04:57:09 AM »
Sliding t-handle with ratcheting socket adapter makes me  ;D ;D ;)...Larry
« Reply #18 on: February 21, 2012, 05:20:04 AM »
An extendable magnet.
Offline Lars
« Reply #19 on: February 21, 2012, 05:22:24 AM »
Valve spring compressor.
Shotgun - if no other tools work.... ;)
...if you got the ability to act...
Offline Kong
« Reply #20 on: February 21, 2012, 06:44:09 AM »
4.5" angle grinder
120 volt welder
compressor (and all that follows)
Very high quality cordless drill
Complete drill index
die grinder and two or three good burrs
Large vice
2002 FXSTD/I  Softail Deuce
2001 Acura (Honda) CL Type-S
1986 Honda Rebel, 450
1978 Honda CB550K
1977 Honda CB550K
orange550
« Reply #21 on: February 21, 2012, 09:42:27 AM »
Hi all,
Rick.
You mean a Robertson. :) Invented by a Canadian!
I bought a set of Honda tappet gauges. Each one is pre-bent and has only 1 size on each end. Saved me from dicking around with bending a cheapo set. They were hard to find...  automotive tappet gauges don't go down that small.
Offline fmctm1sw
« Reply #22 on: February 21, 2012, 10:21:55 AM »
Hi all,
Rick.
Brilliant!  Some of mine:
1]  Section of PVC pipe with notch cut out of it.  Used with a C-clamp to compress valve springs on small valves.
2]  Clutch nut tool. Impossible to remove a CT90 clutch with out it.
3]  Soda crate/furniture dollies and a 4x4 contraption I use to pull 750 engines.
4]  A pair of grinded down snap ring pliers I use to (attempt to) remove and install master cylinder circlips.
5]  Various cleaning agents used for anything other than their intended purpose.
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline bharvey60
  • Adolescent mind stuck in an adult body
« Reply #23 on: February 21, 2012, 10:29:19 AM »
Spanner wrench for removing front wheel bearing seal.
Bill Harvey
CB750K3
85 Yamaja FJ 1100
98 BMW R1100RT
State College, PA
« Reply #24 on: February 21, 2012, 10:55:50 AM »
small hobby soldering iron and a good sharp wire cutter/stripper.
adjustable face pin spanner
10pc assorted miniature diamond file set (for cleaning and fixing bad bolt threads)
