Author Topic: Floatvalve without needle spring?  (Read 1341 times)
gugge
« on: February 21, 2012, 09:44:27 AM »
I just disassembled a flee market set of well preserved Honda CB350F KEIHIN carburetors, and to my surprise there obviously are no internal springs in the float needles – no spring function at the tip pointing at the float!
Have anyone ever observed this?
The float needles on my working Honda CB350F are all spring loaded!
Denmark
Offline fmctm1sw
Re: Floatvalve without needle spring?
« Reply #1 on: February 21, 2012, 10:12:43 AM »
They're probably gummed stuck...
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #2 on: February 21, 2012, 10:35:31 AM »
^ +1
Soak in some carb dip and see if that fixes 'em.
gugge
« Reply #3 on: February 21, 2012, 10:40:47 AM »
I will try - thanks!
« Reply #4 on: February 21, 2012, 10:42:37 AM »
Soaking and also working them over with a heat gun may help soften the varnish also. Some never come back,others I have had, did return to working.
« Last Edit: February 21, 2012, 11:09:18 AM by ekpent »
gugge
« Reply #5 on: February 21, 2012, 11:01:37 AM »
I have them allready put into carb cleaner, and will give them a try tomorrow!
Heat is sweet :)
gugge
« Reply #6 on: February 22, 2012, 10:01:34 AM »
One night in carb cleaner did the job - the spring is working again.
