Author Topic: Parts back from powdercoaters but (?)  (Read 4109 times)
Offline messeduptriple
« on: February 24, 2012, 08:45:39 AM »
I totally forgot to take out the bushings in the swingarm..where can I get them at? Hardware store ? Any websites? 76 550
Anyone have them to sell cheap?
Thanks.
Sent from my PC36100 using Tapatalk
Offline LesterPiglet
  • 1977 CB550F2
Re: Parts back from powdercoaters but (?)
« Reply #1 on: February 24, 2012, 09:51:29 AM »
http://motorcycle-europe.info/52108457300.php
The part number is in there so you can search closer to home.
« Reply #2 on: February 24, 2012, 09:52:12 AM »
better talk to hondaman
Offline Really?
« Reply #3 on: February 24, 2012, 10:39:43 AM »
Did the tank get PCed too?
The Wife's Bike - 750K5
The Kid's Bike - 750K3
nomad
« Reply #4 on: February 24, 2012, 10:43:45 AM »
+1... PM him.  He'll steer you in the right direction.
Re: Re: Parts back from powdercoaters but (?)
« Reply #5 on: February 24, 2012, 10:46:14 AM »
yea tank done as well
« Reply #6 on: February 24, 2012, 11:08:05 AM »
how do I get ahold of him?? I'm on a tapatalk app on phone... Not sure how I can search him..there's no search bar
nomad
« Reply #7 on: February 24, 2012, 11:10:52 AM »
See if this link works for you... http://forums.sohc4.net/index.php?action=pm;sa=send;u=2043
« Reply #8 on: February 24, 2012, 11:23:19 AM »
Thanks nomad!
Offline matt mattison
« Reply #9 on: February 24, 2012, 02:56:00 PM »
Honda still makes those plastic swing arm bushings. I just bought a set,they cost me about $60. Just carefully press or tap theM in with a rubber Mallet.
1975 CB550F
2011 MV Agusta Brutale 1090RR
bollingball
« Reply #10 on: February 24, 2012, 03:25:38 PM »
mess This is HondaMan's web site. Contact info inside.
http://sohc4shop.com/catalog/product_info.php?cPath=23&products_id=46
                                     Ken
« Reply #11 on: February 24, 2012, 10:19:34 PM »
Well my ? Is would it work if I took it to a local fabrication shop and have them try and rig something up for bushings? I found these swingarm bushings but there 50$
 http://www.partsnmore.com/parts/honda/cb550/?filters%5Bcategory%5D=chassis&filters%5Bfitting%5D=custom
Honda man said I would have to send the swingarm to him and he would need to fit it and had a story on why. Said it could cost on the high side of 200$ ...that's not what I want to spend at all on these bushings. Would it be ok if I just bought a used one from eBay for 30$ and take the stuff of there??? Would that work or is there more to it then just doing that?
« Reply #12 on: February 25, 2012, 02:09:04 AM »
For 200 bucks the machine shop would likely turn you a set of brass bushings and install. What you need to do is give them the dimensions. I'm sure someone has a new set  they could  mic then draw dimensions for you.
what about that site that I posted ...if I bought those will it work out fine? Would I just tap them in?
« Reply #13 on: February 25, 2012, 03:43:55 AM »
Since those are brass, I wouldn't try to tap them in. Any local mechanic or machine shop could probably press those in for next to nothing. I would make sure that where the bushings press into is very clean and smooth before having them pressed. A good shop should do that anyway, but it's better to be sure.
1975 CB550F
« Reply #14 on: February 25, 2012, 04:58:51 AM »
Does 50$ sound like a good price for those? I'm just curious if anyone has tried to do some hardware store stuff on them for pennys on the dollar and have them work fine??? Or so you think this is what I have to get no questions asked? I will if I have to then.
Offline Lostboy Steve
« Reply #15 on: February 25, 2012, 06:56:33 AM »
See?! I told everyone it was possible. I did my 68 z50 tank that way. Good Call I might have my 77 550k tank done now.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Re: Re: Re: Parts back from powdercoaters but (?)
« Reply #16 on: February 25, 2012, 07:52:56 AM »
I like it... It looks sharp . I'm gonna toss on some tank grips and I have the Japan attack decal all in black ...gonna toss that on the top of the tank.
Offline Harsh
  • 74 CB750 and two 72 CB350's
« Reply #17 on: February 29, 2012, 11:03:25 AM »
I gotta ask...why would you need to remove the bushings before having the swingarm powdercoated?
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #18 on: February 29, 2012, 12:02:37 PM »
Since I see you have the single zerk grease fitting is your swingarm the design that switched to steel bushings or are they brass?
I had Hondaman perform his magic on my swingarm before I powdercoated it, works like a charm.
Odds are if you have the single zerk and steel bushings you swingarm is mostly useless without a rebuild- grease would never make it to the bushings in your case.
« Reply #19 on: February 29, 2012, 12:43:18 PM »
$200 is worth it.
After all, these are parts that help keep you upright.  ::)
« Last Edit: February 29, 2012, 01:24:21 PM by flybox1 »
« Reply #20 on: March 01, 2012, 06:19:41 PM »
I just took a drive to my Honda shop about hour away... They ordered the oem bushing and will install it for me. About 40$ total... That's not bad.
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #21 on: March 02, 2012, 08:51:12 AM »
Anybody ever try these? Same part number for teh CBX as the 76 CB550. Pretty cheap for brass.
http://cbxperformance.com/oscommerce/product_info.php?products_id=166&osCsid=19975628a00b1debcb0a51b74c76fe48
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
nomad
« Reply #22 on: March 02, 2012, 09:20:21 AM »
Lok at the SAE 841 bronze bearings here... http://www.mcmaster.com/#catalog/118/1126/=ghmxrs.  I know Hondaman likes the Oilite (oil impregnated) bearings and that's what these are.  If they carry the right size, they're a lot more affordable than those you linked to (roughly 1/5th of the price).  You just need to make sure they have all the same dimensions.  And make sure to order 2 of them (since they're sold individually).
« Reply #23 on: March 05, 2012, 05:41:11 PM »
Well messeduptriple i have decided to pc my tank but with a twist. If youre interested im going to start a new thread on it as soon as i get my tank in from ebay! Its going to be sweet.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
« Reply #24 on: March 06, 2012, 07:29:34 AM »
sweeet... Yea ill keep an eye out for the thread!! I'm curious what the twist is though... :^)
