Author Topic: CB500 Shaft Seal Part Number - Confirmation  (Read 1621 times)
Offline Chachi
« on: February 24, 2012, 03:47:53 PM »
My mechanic is tracking down a leak. From the outside, fluid comes out around the base of the shifter. He suggested the easiest thing to do is replace the following shaft seals: shift, clutch, counter/output. Note: I've already replaced my oil pressure sending unit as that was related to a leak as well.
I found the info below from Dave500 on a post regarding a similar issue. Are these the part numbers I need to order based on mechanic's suggestion? Simple order from dealer, still available?
they aint costly replace all the seals that side of the engine.
counter shaft seal(behind the sprocket) #91205-283-015
clutch push rod seal                                #91203-292-005
shifter shaft seal                                     #91202-KFL-841
shift drum seal(behind neutral switch)    #91202-426-003
73 CB750 K3
72 CB500 K1 - Sold
75 MR50 Elsinore K1
Re: CB500 Shaft Seal Part Number - Confirmation
« Reply #1 on: February 24, 2012, 05:00:52 PM »
thems the numbers,i think you can download the 500 parts list here ?
Offline Chachi
« Reply #2 on: February 24, 2012, 07:15:17 PM »
They're on the parts fiche with different terminology. I'm new, so I need all of the clarification I can get.
Fiche...
Oil seal, Transmission #91205-283-015
Oil seal, Transmission #91203-292-005
Oil seal, Gearshift spindle #91202-KFL-841
Oil seal, Gearshift fork @ drum #91202-426-003
Thanks.
73 CB750 K3
72 CB500 K1 - Sold
75 MR50 Elsinore K1
« Reply #3 on: February 24, 2012, 09:09:35 PM »
yep i just rechecked them,they are what you need to do all the seals on the left side,apart from the oil pump if it isnt leaking,youll need 2 times 13.6mm x 2.4mm and one times 47mm x 3.2mm o rings,i get them from a bearing supply shop,,they have a $5 minimum so i end up with two sets of them.
