Author Topic: MLS Head Gasket  (Read 7003 times)
Offline mick7504
MLS Head Gasket
« on: February 24, 2012, 06:29:20 PM »
Here are some pictures of the MLS Head Gasket from Kenny (Cyclex)
They are a 3 piece gasket held together with 4 small rivets.
Overall thickness (uncrushed) is .0305".
The centre "shim" is plain steel measuring .010" and both of the outers are coated each side.
They should be a good thing.  8)
If I was you
I'd be worried about me.
Re: MLS Head Gasket
« Reply #1 on: February 24, 2012, 06:33:48 PM »
Yea these should be the cats ass Mick. Mike Rieck has been singing their praises too.
Offline cbr954
Re: MLS Head Gasket
« Reply #2 on: February 24, 2012, 06:43:34 PM »
Just put one in my new 836 motor. Just fired up yesterday, so far so good!
03 CBR954RR, 72 750 chopper(970cc
F2 head), 2017 CRF450R, 2001 CR250R, 72 CB500, 79 XR250, 04 CRF50,70's soon to be rebuilt cb750 drag bike.
Offline Jim F
  • go baby go
Re: MLS Head Gasket
« Reply #3 on: February 25, 2012, 06:56:49 AM »
This is the gasket that I plan on running in my turbo build
Jim
2002 RC51 1000 (SP2)
1983 GS1100EC Suzuki
1992 KTM500 2 stroke
1975 CB750/836 Honda
1978 GS750/840 Suzuki
Offline tweakin
  • tear down
Re: MLS Head Gasket
« Reply #4 on: February 25, 2012, 07:08:50 AM »
I running one on my 915 and could not be happier.
Offline Bill/BentON Racing
    • BentON Racing
Re: MLS Head Gasket
« Reply #5 on: February 25, 2012, 08:30:55 AM »
Also plan on using them! Sure look good.Way to go Ken.Mike you got any stacks for 31's or where to get,also you know which K&N's fit? Thanks,Bill
BentON Racing Website
BentON Racing Facebook
Offline dragracer
  • CB750F Dragbike
Re: MLS Head Gasket
« Reply #6 on: February 25, 2012, 03:52:22 PM »
The later model bikes have been using these for years now. No gasket sealer recommended or required.
Glad we now have them for the SOHC's.
Offline cbr954
Re: MLS Head Gasket
« Reply #7 on: February 25, 2012, 04:07:27 PM »
I know Cycle X has them, they dont list different thicknesses but maybe they offer them?. Dynoman has them in a couple of different thicknesses also.  I also used Dynomans coated steel base gasket, those are available in different thicknesses as well.  I'm glad they are available now too, just wish they weren't so expensive!!
Offline dragracer
  • CB750F Dragbike
Re: MLS Head Gasket
« Reply #8 on: February 25, 2012, 09:02:12 PM »
I assume that they are throw away gaskets??? Once its compressed thats the end of the usable life. Great for a street bike but not so good for a race bike application where you're tearing it down once or twice a season. Ouch!!
Offline Leino
  • Not much of an
  • in drag racing since 2005
Re: MLS Head Gasket
« Reply #9 on: February 26, 2012, 01:02:59 AM »
Useable two- or three times with copper.
My friend uses them on his 1246c GSX-R dragbike, never had a leak.Well I suppose he had a leak several times a day but no oil leak ;)
  • Moderator
Re: MLS Head Gasket
« Reply #10 on: February 26, 2012, 03:59:24 PM »
When you have to get up three times during the night you have a problem. ;D ;D ;D ;D ;D ;D ;D ;D
Offline Leino
  • Not much of an
Re: MLS Head Gasket
« Reply #11 on: February 26, 2012, 10:56:07 PM »
NOT looking forward to it  ::)
Offline dragracer
  • CB750F Dragbike
Re: MLS Head Gasket
« Reply #12 on: February 27, 2012, 05:09:25 AM »
I use my copper head gasket twice. Its got an o-ringed block so once the gasket bites into the copper o-ring, i just clean it up, anneal it then flip it over for re-use. In a pinch, i'll use it 3 times. Still gets hung up on a nail- just in case-lol.
Offline aggiepike
    • Compare and Save on Electric Rates in TX
Re: MLS Head Gasket
« Reply #13 on: February 27, 2012, 02:56:57 PM »
I got on from cycle x for my 836 kit that is being put in. Hopefully no issues will let you guys know.
K1 CB750 (836)
Offline bert96
  • past ride
Re: MLS Head Gasket
« Reply #14 on: February 27, 2012, 03:39:26 PM »
Is that true that we need to shave the head to install this gasket?
Bert
QA50 1969,ST-90 1974,mb5 1982,rz350 1983,shadow 1100 1985,vf1000f 1985,BMW K1 1990,shadow tourer 1100 2001,vfr 750 1994,vtr250 199?
Offline cbr954
Re: MLS Head Gasket
« Reply #15 on: February 27, 2012, 04:20:57 PM »
You need to have the head surface and the top of the cylinder surfaced to the spec for the MLS gasket.  It is a very fine finish when they are done.  There is a big difference in the finish between a standard finish and the correct finish for these gaskets.  Plus the surfaces need to flat, no warping across the surface.
Offline Jim F
  • go baby go
Re: MLS Head Gasket
« Reply #16 on: February 28, 2012, 05:03:00 PM »
I will also find out at weeks end weather or not they can be laser cut to fit
over bore motors 77mm plus
I sent some up after I gently pulled them apart
will make a fixture to locate on the dowel pin holes and then laser
cut each one separately
will keep you posted
Jim
Offline stueveone
Re: MLS Head Gasket
« Reply #17 on: March 10, 2012, 06:46:29 PM »
Huh. CycleX makes no mention of needing to have the head or cylinder decked. That's strange?
Re: MLS Head Gasket
« Reply #18 on: March 10, 2012, 07:11:44 PM »
All very true.
Offline cbr954
Re: MLS Head Gasket
« Reply #19 on: March 10, 2012, 08:22:38 PM »
You will have to ask Ken about it, Dynoman also sells MLS gaskets, Cometic brand...
MLS stands for Multi-Layer Steel. MLS head gaskets are comprised of three layers of stainless steel. The outer layers are an embossed viton coated stainless steel providing a superior seal with excellent rebound characteristics and are corrosive resistant. MLS head gaskets reduce bore distortion and withstand extreme cylinder pressures.
Cometic Multi-Layer Steel (MLS) head gaskets go on dry because they are coated with a sealant. Each MLS head gasket is coated with a .001" thick viton rubber that is bonded to the outer stainless steel layers. Adding an additional sealer can hinder the performance of an MLS head gasket.
MLS head gaskets require smooth, flat and true head and deck surfaces to seal. Most of the time with o-ring setups the wire and groove fall where our gasket’s combustion seal is located; therefore, the wire will hold the gasket and not allow proper compression while the receiver grooves allow combustion gases to escape.
A surface finish of 50 RA (roughness average) or finer, is recommended for a proper gasket seal. Anything rougher may conflict with the gasket design.
When using MLS head gaskets always refer to the manufacturer of the fastener to determine accurate torque values
« Last Edit: March 10, 2012, 08:24:23 PM by cbr954 »
