Author Topic: replacing the swing arm zirk w/ metric: 6 or 7mm?  (Read 1057 times)
Offline grumpy
  • ..... '73 750K3 .....
« on: February 25, 2012, 12:15:17 PM »
I'm gonna replace the OEM swing arm grease nipple.
Most people seem to use 1/4"
I have no use for a  1/4" tap but I do use metric - so I was gonna get a metric tap and zirk.
Should I get 6 or 7mm?
6 is a bit under 1/4" and 7 is a bit over... which would work best?
<-------  750K3
« Last Edit: February 25, 2012, 12:18:40 PM by grumpy »
Offline kerryb
  • Not a very
Re: replacing the swing arm zirk w/ metric: 6 or 7mm?
« Reply #1 on: February 25, 2012, 07:42:32 PM »
the easy route seems to be , will there be enough metal to tap after drilling the pilot hole for a 7mm tap?
Offline City Boy
« Reply #2 on: February 25, 2012, 08:30:13 PM »
Hey Grumpy.I just put new fittings in a pal's 750 swing arm last night.I used 6 mm.Slight drilling required first to get sizing prior to tapping.   Rock On
'52 Kiekhaefer Mercury Rocket Hurricane KG4H
'70 750/RC 1000 Original Owner
'83 1100F
Offline City Boy
« Reply #3 on: February 25, 2012, 08:33:19 PM »
Maybe I spoke too soon.Are you replacing the single fitting style or type with one at each end of shaft.I did the twin type.
'83 1100F
Offline grumpy
« Reply #4 on: February 25, 2012, 09:21:49 PM »
I have one at each end - early K style.
IIRC the later Ks had a single one in the middle - right?.
Offline City Boy
« Reply #5 on: February 26, 2012, 06:27:15 AM »
Not sure,but I also have installed one in centre of arm on same machine.  Rock On
'83 1100F
Offline grumpy
« Reply #6 on: February 26, 2012, 09:54:48 AM »
What size drill did you use for the 6mm?
Offline lone*X
« Reply #7 on: February 26, 2012, 12:00:28 PM »
Grumpy, Google is your friend:  Searched " what size drill for 6mm tap "  and found:
http://www.kramerusa.com/DrillTapChart.htm
Lone*X  ( Don )
75 CB550K1
VTX1800C for two up cruisin.
Offline tomkimberly
« Reply #8 on: February 26, 2012, 12:11:10 PM »
Standard tap size for grease fittings is 1/8"-27.
Tom
Offline grumpy
« Reply #9 on: February 26, 2012, 06:33:45 PM »
That's a useful resource.
Thanks!
Offline Flying J
« Reply #10 on: February 26, 2012, 08:11:05 PM »
Good to know. I need to change the zirk on 2 of mine and all my taps are metric so i figured i would just use the 6mm zirks i have already.
