Author Topic: I would like to hear your .02 on my 75 cb750ss. 1st timer here, looking to learn  (Read 4778 times)
Offline Flying J
Get a photobucket account and then post pictures from there. The white stuff is normal. Do you know how to clean the carbs? Its not just the bowls you need to clean. You need to pull every jet and clean every hole to be sure they are clear. Do a search to see how its done.
Offline 75 super sport
I am able to clean carbs, it seems like water corrosion, doesnt want to come off worth anything. Are the carbs toast? thanks guys
"Smoke em if ya got em"
Offline BeSeeingYou
You can post pictures directly here but you need to shrink them down to under 254k in size.  Using photobucket you can post them whatever size they are.  If the carbs are really gunked up you may have to do a more complete tear down and cleaning than I had to with mine.  Mine were fairly clean when I first opened them up.  Let's see what your pictures look like and go from there.
« Last Edit: February 26, 2012, 02:02:51 PM by srust58 »
http://i1054.photobucket.com/albums/s492/75supersport/carbcb750.jpg  There is carburetor #1 i believe(far left), this is the worst one. The others arent much better. Almost look pitted   :-\
Offline LesterPiglet
  • 1977 CB550F2
Waters been in there. The brass will be fine but whether you can recover those I don't know.
Here's another. On this carburetor the stop for the floats looks like it may have been eaten away? so the floats just stay wide open and the float valve keeps falling out. http://i1054.photobucket.com/albums/s492/75supersport/IMG_2443.jpg
« Last Edit: February 26, 2012, 02:18:21 PM by 75 super sport »
Whats to say about my motor?? Is that a real bad sign as far as haveing to pull the motor completely apart?
  • 1977 CB550F2
Do I see one of the posts for the float pin eaten away? If you have drained the oil and didn't find any water I think the motor is probably fine.
« Last Edit: February 26, 2012, 02:33:06 PM by LesterPiglet »
Offline BeSeeingYou
The fact that the motor turns over is a very positive sign at this point.  Did you check the compression with a gauge?  The carbs look like you may have some problems depending on how bad the aluminum is pitted or eaten away.  Never had to clean one as bad as that but I wonder if something like CLR would remove the white oxidation so you can see what you have.  Simple Green is often used to clean carbs of gas varnish but not sure if it will remove this.  We have seen some pretty wretched stuff brought  back to life here so don't get to far ahead yet.
not the float pin itself, but the two towers or supports for the float pin are just about deteriorated. I am pretty convinced a new set of carburetors will be my first investment for the bike. I am more concerned about the other side of those carbs, the motor. What should I look for? Obviously, this is because water had been there, but is my motor going to look the same way? Thanks for the help guys.
To post pics:
Open a free acct at photobucket.com
Then, look here...
http://forums.sohc4.net/index.php?topic=70243.msg779527#msg779527
The white stuff is corrosion.
