Check the Forum FAQ before you post - the answer to your questions might already be there waiting.
Prob is not in the studs, imo, but in the thread in the aluminium head. You can use them but got to make sure you change the thread into helicoil or threaded bushings.Rob
Quote from: voxonda on March 16, 2013, 02:43:30 AMProb is not in the studs, imo, but in the thread in the aluminium head. You can use them but got to make sure you change the thread into helicoil or threaded bushings.Rob Got that right Rob
