Author Topic: Vintage sidecar rebuild - new video  (Read 152182 times)
  • Moderator
Re: Vintage sidecar rebuild
« Reply #250 on: August 19, 2012, 10:48:44 PM »
Well done Brian, 3 seconds off the pace with what sounds like a far from perfect bike can't be bad and you did miss out on a practice session, not bad at all mate.
Sam. ;)
Offline Tintop
« Reply #251 on: August 20, 2012, 04:26:36 AM »
Thank Sam.  I'm very happy with how the bike performed.  Goal was to get under 2 minutes, and we only missed by a second. :)
The metallic noise turned out to be the oil catch pan touching down.  Fixed that, then did a '3000 mile tuneup', and complete check over.  The not pulling over 5K was fouled plugs.  Seems the Weber didn't like trolling around at part thottle.  We do a 'Try the Track', were people pay $20 (goes to charity), and get 3 laps of the track on a sidecar.  The jetting change Saturday evening helped top end, but created a low end bog.  It bit on the exit of 5, and hurt the run up the straight.  I had only been dropping it down from 4th to 3rd before.  2nd would have worked now, but really buzzed it on the entry to 5.
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
Offline Syscrush
  • Sold. :(
« Reply #252 on: August 20, 2012, 08:05:51 AM »
The Sunday final was our best effort so far.  Started 8th, finished 5th.
That's a very good result.  BE PROUD!
Offline Old Scrambler
« Reply #253 on: August 20, 2012, 09:17:54 AM »
VERY happy for you and the ride for Lefty-GZ 8) 8)  Those 650 clutches work well enough for ordinary riding.......but needed attention after I sold a bike to a 300-lb. rider ;D
SAM......I've seen wider tracks on a golf-course ;) ;) ;)
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline Really?
« Reply #254 on: August 20, 2012, 09:22:24 AM »
Hey Tintop, that rig is
SICK!!!!!!!!!
The Wife's Bike - 750K5
The Kid's Bike - 750K3
Offline Really?
« Reply #255 on: August 20, 2012, 09:23:36 AM »
If that rig were to end up in BOTM, what bike could even go up against it??
« Reply #256 on: August 20, 2012, 09:33:56 AM »
What were the jetting changes?
Offline Tintop
« Reply #257 on: August 20, 2012, 09:45:39 AM »
I tried a 130 main with 175 air, and F16 - too lean.  Went back to the 140 main, 185 air, and F11.  Top end is very good now, but when the accel pump comes in a low rev it is too rich.  Takes a bit to clear.  This was only happening coming out of the slowest corner.  Being down one more gear would have kept the revs in the right place, and avoided the issue.  The change to the F11 did help overall, and I now have a clean idle.
77 CB550 Cafe build
« Reply #258 on: August 20, 2012, 09:52:23 AM »
What size idle jets?
Offline Tintop
« Reply #259 on: August 20, 2012, 02:12:53 PM »
45F9's scotty.  Thinking maybe going to 40F9's, or 45F8.  Either way I have to P/U some parts.
'edit' - it was idling @ 1800 OK (would like to get it down to about -1500), and idle screws are @ +/-3/4.  Sync is still off slightly as there is a pop when cold (left cylinder?).  Clears up mostly when it is fully warmed up.  The pipes are not helping, and will need to be replaced for next season.  Primaries are about 2" too short, and not quite equal length, as is. :( ::)
« Last Edit: August 20, 2012, 02:25:27 PM by Tintop »
77 CB550 Cafe build
  • Moderator
« Reply #260 on: August 20, 2012, 03:07:45 PM »
Put me down for nominating Brians bike for next month. ;D ;D ;D ;D ;D ;D ;D
Offline brooze72
« Reply #261 on: August 20, 2012, 05:05:49 PM »
Sure would be a "first" having a Yammie powered rig win the BOTM on SOHC4.net :o :o ;D
1972 CB500K1 - restored rider
1981 CB650C - new project
Offline Really?
« Reply #262 on: August 20, 2012, 05:20:55 PM »
I swore it was one of ours. Still sick though.
Offline Tintop
« Reply #263 on: August 20, 2012, 05:31:07 PM »
Would be.... if Honda made a 'pre 73' twin that you could stretch to 750. ;) ;D ;D ;D ;D
The P3 Fiddeman will get a 915+ SOHC though.
77 CB550 Cafe build
Offline brooze72
« Reply #264 on: August 20, 2012, 06:59:28 PM »
Did you just give us a sneek preview of next years project ? ;) ;) ;D ;D
« Reply #265 on: August 20, 2012, 07:28:35 PM »
I'd stick with the 45F9s for now, maybe open the screws to 1 turn to bring the speed down?
Sounds like in any case you have too much pump. What size pump jets are you running, and what size discharge aka accelerator pump back bleed jet? The discharge jet is about the only jet I would find drilling to be acceptable on a Weber. ;)
Offline Syscrush
  • Sold. :(
« Reply #266 on: August 21, 2012, 05:50:36 AM »
Don't stress about them being unequal length - brag about how they're tuned for a broader spread of torque, yielding better driveability! ;)
  • Moderator
« Reply #267 on: August 21, 2012, 08:40:18 AM »
That's why it had these.. ;D ;D ;D ;D ;D ;D ;D
Someone REALLY? messed up ::) ::) ::) ::) ::)
Sam. ;)
« Last Edit: August 21, 2012, 08:42:17 AM by SamCR750A »
Offline Really?
« Reply #268 on: August 21, 2012, 08:51:07 AM »
I Really messed up aye?  My bad.
Offline Tintop
« Reply #269 on: August 21, 2012, 02:33:23 PM »
scotty - Agreed the 45F9's are probably OK.  Just need to get the idle circuit setup finalizied.  The pump jet is a 50, but don't have my setup sheet handy re the exhaust (50?? maybe).  I haven't even started playing with the pump stroke & spring rate, so there's still room for improvement there.  I'm more inclined to think that it's rev related (low rev = low air speed = poor atomization).  The only two corners were it was 'thick', or bogged I could / should have been down another gear.  Note that this only became an issue when I changed from the F16's to the F11's.  The other change was the needle from a 175 to a 200, but that shouldn't have any effect on this, except to keep the wells full(er) @ WOT.
Booze72 - The 13" isn't likely to be done for at least another year.  I'll post some pics later, but it's a true basket case.  That said the 16" is huge fun, and potentially a faster rig @ everywhere we race, but Mosport.
77 CB550 Cafe build
« Reply #270 on: August 21, 2012, 02:56:40 PM »
50 pump jets are a bit on the large side, IMHO. I'm running 35s, with 55 discharge. If you look at the OEM jet settings in the Haynes book, you'll see that most dcoe 40s used 35 pump jets, with discharge jets from 35 to 100.
Offline Tintop
« Reply #271 on: August 21, 2012, 03:16:06 PM »
The 50's are what were in the carb when I got it.  I'll see about getting something smaller to test.  The current bleeds should be OK for now, as their within the range.  I'll have to order pump jets, so I'll have them send some other bleeds as well.
I haven't found a single reference for an XS with a Weber, for street or racing (650 or 750cc's).  Figure when I get it sorted I should eBay a kit. ;) ;D ;D ;D ;D
77 CB550 Cafe build
  • Moderator
« Reply #272 on: August 21, 2012, 03:52:55 PM »
 ;D ;D ;D ;D ;D That's why we love you, you're a total MESS.  ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D
« Reply #273 on: August 21, 2012, 05:33:51 PM »
That's not a bad idea at all, given the popularity of the XS. (Do I get a cut of the proceeds? ;))
I would go to the 35 pump jets; they will give a much stronger stream than the 50s for the same volume of fuel. You might be surprised just how much fuel can be forced through the small squirters  if need be. I had 2 DCOE 40s on a 6.7L motor once. ;)
Offline Tintop
« Reply #274 on: August 21, 2012, 07:21:24 PM »
I'll take a look at what else I may need/want.  It will cost more to ship x2 jets than they cost.
77 CB550 Cafe build
