Author Topic: Vintage sidecar rebuild - new video  (Read 159848 times)
Offline brooze72
Re: Vintage sidecar rebuild - revised video #476
« Reply #525 on: August 25, 2013, 08:57:13 PM »
That's great Brian!  Hell of a showing  ;D ;D :D
What lap time did you run today?
1972 CB500K1 - restored rider
1981 CB650C - new project
« Reply #526 on: August 25, 2013, 09:41:19 PM »
Well done Brian... ;)
Offline bear
  • Leeton in Australia
« Reply #527 on: August 25, 2013, 09:45:05 PM »
Nice one mate. Well done.
Give Hopper a pat on the back for me.
Brian
« Last Edit: August 25, 2013, 09:52:25 PM by bear »
« Reply #528 on: August 26, 2013, 03:46:29 AM »
Yes well done Brian. I doubt very much muscling a rig around at speed with one clip-on & one swinging rudder is the ideal situation.  ;D Good Results.
Offline Tintop
« Reply #529 on: August 26, 2013, 01:02:16 PM »
Not sure about lap time at this point, timing & scoring had a problem with the transponder system. :(
Brian
A pat, and a big thankyou Brian.  I was having an issue with his r/l transition (late) between 8 & 9 in the heat.  Was losing the backend, and getting the chair wheel up to much. ::)   Talked about it, and he made the adjustment for the final.  Just flying through there then. ;D
Thanks Brent, it goes to the top of the list as the best weekend of racing I've ever experienced.  Unloaded this morning, and I don't think there is a muscle that isn't sore.  Only carried the light stuff with the left arm. ;) :)   Also added an exhaust deflector to the 'To Do' list....right toes are slightly crisp.
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
Offline FuZZie
« Reply #530 on: August 26, 2013, 03:26:12 PM »
Congrats!  Sounds like you had a blast!
Offline Tintop
« Reply #531 on: August 26, 2013, 06:15:22 PM »
It was a blast FuZZie.  The new track facilities, and re-surface of the track are world class.  It's always been a fast track, but now its so smooth it just flows.
Checked the raw video, and the good news I got all the front stuff, and most (card is too small!) of the rear.  Also took a couple of photos of the bars.  OH, and for RR and the 'no photo it, didn't happen' photo. ;) ;D ;D ;D ;D
How they should look -
Where they were about lap 4, if they weren't somewhere else, most of the time position ::) -
(CTMP) Mosport 2013 P2 Sidecar Final -
Bear - Re the headline about trail & God.  Going up the back straight in 5th I thought it would be a good time to let my passenger know we had a somewhat serious issue.  As I started to relaxe my left hand grip to point out the right side issue, it started to shake its head.  Decided to tell him later, re-tightened my left grip, and kept the right twisted. ;) :)
77 CB550 Cafe build
« Reply #532 on: August 27, 2013, 01:22:31 AM »
Thanks Brian.... ;D ;)
Offline Syscrush
  • Sold. :(
« Reply #533 on: August 27, 2013, 04:15:07 AM »
Congrats, that's a huge accomplishment!
« Reply #534 on: August 27, 2013, 06:23:18 AM »
Congrats on the great finish Brian and to Brent for his return and new experience...good going guys!
« Reply #535 on: August 27, 2013, 09:15:41 AM »
Congratulations Brian. Nice to see all the R&D and labor work as you wanted. Learning curve never stops though does it. ;) ;D
  • Moderator
« Reply #536 on: August 27, 2013, 11:13:16 AM »
If you can get results like that with the problems you had, how good is it going to be when everything is spot on?
Well done Brian. ;)
Offline Tintop
« Reply #537 on: August 27, 2013, 11:37:02 AM »
Thanks Mike.  Found out this weekend what the bike felt like when new...finally.  As for the learning curve, just got a glimpse of the next part of the curve this weekend. ;D ;D ;D ;D ;D ;D
Well done Brian. ;)
Thanks Sam, that was my big takeaway from this weekend.
77 CB550 Cafe build
Offline Tintop
« Reply #538 on: August 27, 2013, 03:51:00 PM »
Forgot to add Sam, changed beer for the weekend.  No more of that English stuff,  Scottish Tennants from now on. ;) ;D ;D ;D
77 CB550 Cafe build
Offline bear
« Reply #539 on: August 27, 2013, 06:33:09 PM »
Video? :) :) :)
No hurry. Any time in the next five minutes will be fine.
Brian
« Last Edit: August 27, 2013, 06:34:52 PM by bear »
Offline Tintop
« Reply #540 on: August 27, 2013, 06:41:09 PM »
Video? :) :) :)
Brian
I'm having to much fun watching it, soon........
77 CB550 Cafe build
Offline Tintop
Re: Vintage sidecar rebuild - new video
« Reply #541 on: August 28, 2013, 03:54:05 PM »
Here you go Brian, the Saturday Heat race.  1st time out since all the chassis & suspension changes, wasn't sure what to expect.  Learned a few things which got put to good use in the Final.  I'll post that in the next day of so.  Full screen is best. ;) ;D ;D
http://www.youtube.com/watch?v=fFfWWqVuBl8&feature=youtu.be#_methods=onPlusOne%2C_ready%2C_close%2C_open%2C_resizeMe%2C_renderstart%2Concircled%2Conthumbsup%2Contimestampclicked&id=I0_1377729227718&parent=http%3A%2F%2Fwww.youtube.com&pfname=&rpctoken=80965961
77 CB550 Cafe build
« Reply #542 on: August 28, 2013, 04:06:57 PM »
You should have got that guy in front of you Brian, he was clearly holding you up in places....  Cool video mate... ;)
Offline Tintop
« Reply #543 on: August 28, 2013, 05:09:52 PM »
Sit tight RR, more to come. ;)
He had a rear tyre going down, and kept changing lines.  That sound of silence going into T2 on the last lap is everything locked up (when he moved wide, because of the tyre).  Plan was to pass him there. :(
77 CB550 Cafe build
« Reply #544 on: August 28, 2013, 07:01:32 PM »
Nice Heat race, sometimes you eat the bear and sometimes it eats you...  Glad you had a successful weekend racing without any major issues that prevented you from finishing. Always good when you can finish a heat race or race...real disappointing when something happens to prevent it.  Glad the rig is running well and isn't throwing lots of issues to sort out.
Front GoPro has some RFI interference issues apparently, it isn't happy given it's recording issues.
Good luck with the coming races...  Maybe you can post some more podium finishes and move up in points.
David
Offline Tintop
« Reply #545 on: August 28, 2013, 07:52:29 PM »
David if you mean the wavy stuff, it's because it is mounted on the bubble.  The bubble picks up the vibration and causes the camera shake.  Mounted it on the chair bubble for the final, better but still has shake.  Winter project to improve the mounts.
77 CB550 Cafe build
Offline FuZZie
« Reply #546 on: August 29, 2013, 04:34:37 AM »
Thanks it was cool to see, That one cone commit suicide or were you getting a bit wide? ;)
Offline Tintop
« Reply #547 on: August 29, 2013, 11:06:14 AM »
There was mention @ the driver's meeting about a cone being on the edge of the track going into T5.  It was right at my wide turn-in point.  Manage to miss it for 4 laps, didn't on the 5th.  The front passenger loop got it on entry, and the outside curbing on exit removed it.  You can see it pop out beside the exit cone in the rearview camera. ;D ;D ;D ;D ;D ;D
77 CB550 Cafe build
Offline SF
  • I burn gas very well
« Reply #548 on: August 29, 2013, 11:53:14 AM »
real cool TT thanks for sharing
92 wr250 sold
98 zx6r sold
04 zx10r
73 cb350 twin
75 cb550f
75 cb550f
72 r5c
rgid springer bobber project
Offline brooze72
« Reply #549 on: August 29, 2013, 05:35:01 PM »
Here's a quick crappy clip from turn 2, I never realized racing is so hard to video.  Brian & Hopper were too fast for me :)
https://www.youtube.com/watch?v=_5xuT4tFEuE
