Author Topic: Nuts,Bolts, etc  (Read 4583 times)
kmenzel
Nuts,Bolts, etc
« on: May 08, 2005, 06:13:17 AM »
Anyone have any suggestions about getting bolts,washers and other small parts coated.  I know people have said to get things zinc plated.  I am having trouble finding someone to do it in this area (Minnesota).  I can just as easily ship it out.  Also, where is the best place to find replacement bolts, etc.  What type does anyone suggest
MetalHead550
Re: Nuts,Bolts, etc
« Reply #1 on: May 08, 2005, 06:27:49 AM »
Theres a couple guys on ebay who sell stainless steel bolt kits for our bikes and many others.  They are allen head bolts too so no more stripping out phillips heads.  I think they run about $15 to $30 shipped, depending on if you get a complete set or just a kit for the engine side cases.
Chrisboden
Re: Nuts,Bolts, etc
« Reply #2 on: May 08, 2005, 07:16:51 AM »
Any details on these? I'd love to find one of those kits for a 75-550.
Bobby
Re: Nuts,Bolts, etc
« Reply #3 on: May 08, 2005, 07:58:20 AM »
I bought a kit of 60 stainless allen bolts for my CB750K from eBay for $29 and EVERY bolt fit right and looks terrific!  Very happy with this purchase.  The seller has a set for CB550's on eBay now at
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=4547173011&category=35595&sspagename=WDVW
If the auction has ended, his eBay useraname is www-dot-netgap-dot-com and you can search for his items.  I emailed them with a few questions and they were great folks to deal with.
-Bobby
Offline Gordon
  • 750K1, 550K2
Re: Nuts,Bolts, etc
« Reply #4 on: May 08, 2005, 08:27:36 AM »
http://www.crc2onlinecatalog.com/ sells a set of allen head bolts for $20.  They worked great on my 750.  They're listed under "motor parts".
Offline Tim.
  • www.DOTHETON.com
    • DO THE TON
Re: Nuts,Bolts, etc
« Reply #5 on: May 08, 2005, 08:36:41 AM »
It is far cheaper and much more accurate to simply go through your parts manual, make a list of all the bolts/nuts/washers you want to replace and then go to a fastener company and buy them.
Here in the Toronto area, I went to Brafasco.  They actually make fasteners.  I replaced nearly every bolt and washer I could with stainless hex-head bolts (allan key).  Even the little bolts holding the signal/brake light lenses were available.  Very long and skinny.
Heck, the bolts holding my leads to my battery are stainless hex-heads ;)  The bolts clamping the signal lights to the stalks, engine casing, carb float bowls, intake boot clamp bolts, bolts clamping the left and right controls to the bars, headlight bolts (the three on the bucket) etc. etc.
The parts manual gives you the size and length of every bolt on the bike.  Just put them into a spreadsheet and go shopping!
Offline kghost
Re: Nuts,Bolts, etc
« Reply #6 on: May 08, 2005, 08:58:46 AM »
There are several companies that sell zinc plating stuff. If you want 100% original nothing beats re zincing the bolts you have. If not go with the stainless allen head.
Eastwood Co. makes a starter kit for zinc.
Stranger in a strange land
Re: Nuts,Bolts, etc
« Reply #7 on: May 08, 2005, 09:10:11 AM »
Be sure to use anti seize with those stainless fasteners. I prefer copper anti seize.
Offline Paul
Re: Nuts,Bolts, etc
« Reply #8 on: May 08, 2005, 03:56:23 PM »
I am facinated by questions regarding the fasteners on these bikes, Mainly because I live in "Metric Land" and all these are available for "Cents". I have replaced most of my fasteners with stainless, ( grab a few bolts from work on the way home without a thought.) but  note ...they are not as strong as the HSS or carbon steel ones. (Do they need to be??) I ground off the markings on the heads and polished them..look original. I should really go into business supplying these if they are so difficult to acquire! ;)
Paul.
It hurts to admit when you've made mistakes, But when the're big enough, the pain only lasts a second
Offline Tim.
  • www.DOTHETON.com
    • DO THE TON
Re: Nuts,Bolts, etc
« Reply #9 on: May 08, 2005, 04:12:54 PM »
Fellow member of the Order of 10, which land of metric do you live in?
Offline Paul
Re: Nuts,Bolts, etc
« Reply #10 on: May 08, 2005, 04:23:18 PM »
Ireland, and it's late here..........I know 'cos I'm getting angry looks, bless her, She has the patients of a saint.
Paul.
kmenzel
Re: Nuts,Bolts, etc
« Reply #11 on: May 08, 2005, 06:37:26 PM »
Thanks alot for the information.  Here in the US metric are very difficult to get your hands on.  I checked with many of the best hardware stores and the supply is very limited.
Re: Nuts,Bolts, etc
« Reply #12 on: May 08, 2005, 06:52:20 PM »
Not that hard- I'll post some places tomorrow.
Offline mick750F
Re: Nuts,Bolts, etc
« Reply #13 on: May 08, 2005, 07:58:05 PM »
   I came across this place, Maryland Metrics..."http://www.mdmetric.com, a while back while looking for metric screws. It looks like they carry a wide line of fasteners and tools. I haven't used them so can't vouch for them.
Mike
« Last Edit: May 08, 2005, 08:07:59 PM by mick750F »
Glosta, MA
Offline kghost
Re: Nuts,Bolts, etc
« Reply #14 on: May 08, 2005, 09:40:45 PM »
Ok try this link for zinc plating at home, Has a kit for like $69.00
www.eastwoodco.com/jump.jsp?itemID=134&itemType=PRODUCT&path=1%2c2%2c389%2c400%2c407&KickerID=49&Kicker
Hope I typed that right.
Offline dpen
Re: Nuts,Bolts, etc
« Reply #15 on: May 09, 2005, 12:20:42 AM »
As mentioned by someone very wise - use anti seize. Stainless fasteners & alloy love each other - so much that you will never get them undone.
Any reputable auto place will have suitable gunk.
Re: Nuts,Bolts, etc
« Reply #16 on: May 09, 2005, 07:32:08 AM »
Here's a place that has a good assortment  http://www.mmsacc-stainless.com/
Chrisboden
Re: Nuts,Bolts, etc
« Reply #17 on: May 09, 2005, 08:17:16 AM »
Can someone please post the details of antiseize? I understand the why and what for, I'm looking for good/bad brands and types and the reasoning therof. How do you use it, just a little or gobs? Where? Should it be used on all bolts, or just certain ones?
Offline Quail "Owner of the comfortable k8"
  • Now thats good eaten!!
Re: Nuts,Bolts, etc
« Reply #18 on: May 09, 2005, 09:53:07 AM »
There is at lest 3 different bases for anti sieze.  1 useds alum (for alum), 1 uses tin (for steel), 1 uses copper (for steel, bronze/brass)
These all claim to work to work on everything.  use the right one for the right job and who cares who makes it. read the can and it will give the base metal.
These wonderful little birds are great flyers, delicious eating, excellent for training your hunting dog, and just fun to shoot,or stuff and keep around the house.  Bobwhites can be put with other types of Quail and have very large penis's.  Quail are very popular with the babes.
MetalHead550
Re: Nuts,Bolts, etc
« Reply #19 on: May 09, 2005, 05:21:08 PM »
Hey Chris,  one place to use it for sure would be the side case that covers the front sprocket and oil pump on a 550.  Learned that the hard way.  I had to drill one out cuz I stripped it so bad...even using the correct size phillips.
Offline mrblasty
  • Expertly
Re: Nuts,Bolts, etc
« Reply #20 on: May 09, 2005, 11:16:39 PM »
The Eastwood company has a kit for this purpose You can order a free catalog from there web site.
Please disregard if this has been suggested already. Good luck.
I farted and made my son cry.
1973 Honda CB 750
1975 GL 1000
